Question about Kenmore Refrigerators
While away on vacation, the refrigerator quit working and went to room temperature. Turning the thermostat down on return made it start working again but cannot get good temperature control. Is the thermostat the most likely problem?
  • 601 Answers
Check whether thermostat knob turned to the proper setting? If not, reset it.
Hope this helps
Thanks
Smith.
Posted on Sep 10, 2009
Temperature control in fridge is turned all the way down but still too cold-25*, freezer=10*. What can i do? Amana SZD27ME side by side
Turning down the dial is not recommended as it does not turn the temperature down. Please return it the factory setting. If your temperature is too cold in the fridge, it may be the timer or thermostat. If it its in the freezer, it's the thermostat. If it both, you have a bigger problem, such as the compressor may be malfunctioning.
Jan 13, 2015 | Amana Refrigerators
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
If i am away for any length of time, do i put the temp on vacation? does the water still get warm?
Since you didn't provide the brand & model of the thermostat, only generic help can be provided.
Most furnaces that run on oil or gas, make hot water all the time, 24 / 7 - winter, summer and everything between so to speak. They are controlled by an aquastat that may be set for any value between 140 - 180 degrees F. This is called "hot start" - simply because when the thermostat is set to a temperature higher than the room (turning heat ON), the water is already hot in the furnace, and is circulated immediately. If it was a "cold start", you'd have to wait for the water in the furnace to heat up from room temperature. This would substantially increase the amount of time it would take to heat the room.
Generally, the "vacation mode" simply halts the program from running. If your thermostat changes temperatures several times during the day / night, it will simply hold the lowest temperature - or a predetermined temperature built in - or chosen by you. You'll need to consult your manual to determine just how your thermostat handles the vacation mode setting. Post again if you can't find the manual - but tell us what brand and model it is.
I hop ethis helps - good luck!
Many heating thermostats don't allow for setting a temperature below 45 degrees F so freeze ups shouldn't be a problem.
Sep 30, 2010 | Heating & Cooling
Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Stopped working.Lights working.Di last year
Without the age and model number makes it a problem diagnosing. However, it is not unheard of for a cold control (thermostat) to shut off the machine and hang up and refuse to return to the on position. The cold control on temp is usually about 37 degrees. If left off for 8 hours, the sensing bulb on the thermostat would reach room temperature, and with that additional temperature (heat) could cause enough pressure on a balky thermostat to reset to the on position.
Oct 30, 2009 | GE Refrigerators
Neither refrigerator nor freezer cooling.
sounds like the compressor or relay went out. if the compressor is hot turn off and let cool to room temp. and try it then [a few hours] , if it is not hot then replace the relay on the compressor.
Phil
Jun 10, 2009 | Kenmore 52582 / 52584
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
