FixYa.com
Tags:
Gateway FPD2485W Television
Slow start (by 3 users)
posted by Steve Brady on Dec 10, 2007
Using this as a computer monitor (via DVI), if I turn the monitor off using the power button, when I turn it back on again, I get a black screen with the Gateway logo for 57 seconds, and then after the picture appears, the monitor superimposes a big "DVI" icon over it for another 57 seconds. Is this normal? Obviously, waiting nearly two minutes every time is getting a bit annoying.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by jomamaW, posted on May 01, 2008
I have had my Gateway FPD2485W for several months working fine. It is plugged into my UPS. I would turn off my monitor every night, leaving the computer on. Every morning turn it back on. Suddenly about a month ago I am getting the same Gateway logo that fades and stays on much longer than usual. Then the DVI logo stays on a long time as well.
I personally don't see how plugging it into another outlet is going to solve the problem since it worked fine for months the way it is. Now, I use a screen saver and just leave the monitor on all the time. But occasionally the power button gets touched accidentally and the monitor goes off....grrrr then I turn it back on and wait for the two logos to do their thing.
Comment by Guest, posted on Feb 13, 2008
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or a different wall outlet by removing any surge suppressors." I did that and it works. It might be a certain kind of power bar they do not like. It worked for me so try that and see if that helps.
Best Solution
posted on Jan 11, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes, I have the same problem. Of course its out of warranty and Gateway isn't really big on support once your warranty expires.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 12, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
same problem here - i'll try removing the surge supressor
Solution #3
posted on Mar 31, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
ljkkl
Can you Help with these Flat Panel Televisions problems?
connection
i just purchased a 40"lcd... Answer This...
Gateway fpd2485w lcd shows...
Hi I have a Gateway fpd2485w... Answer This...
question about the your 24
What parts are left over from... Answer This...
HDMI input - not scaled and not...
When I attached Samsung... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
