GE Monogram® ZISS420DMSS Side by Side Refrigerator
Problem for GE Monogram® ZISS420DMSS Side by Side Refrigerator
The freezer temp is fine but the fridg temp is 50
By janicebclark on Sep 10, 2009
The freezer temp is fine but the fridg temp is 50 degrees. It will not get colder than that. I have left it off for 24 hours to defrost and turned it back on and this did not solve the problem.
Comments:
Sep 11, 2009
- I have turned off the fridg for 24 hours on 2 different occasions. I have had 5 service calls so far and it is still too warm in the fridg. I have had the fan and motor replaced, seals, condensor checked,defrost timer replaced,thermostat and drain heater installed. Adjusting the temp in the fridg makes no difference it is running at 50 degrees. The freezer is working fine. Any other ideas other than junk it? It is 10 years old.
Sep 20, 2009
- After changing the damper that fixed the temp issue. It runs fine now a little on the cold side but within normal limits. Thanks!
Solution #1
posted on Sep 20, 2009
Not Rated)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 615 votes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.(make sure this fan is running. Hold the door switch in in order to check it while looking in the freezer.) There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Was this helpful?
Yes
No
Solution #2
posted on Sep 10, 2009
Not Rated)
anythingfix
Rank: Wiz
Rating: 82%, 59 votes
try moving the temp around,then if you tryed that already then defrost your frige turn off completly for one day if that dont fix it check if switch is working,last thing is the change the compressor
Was this helpful?
Yes
No
Popular Solutions for GE Monogram® ZISS420DMSS
Questions and Unsolved Problems for GE Monogram® ZISS420DMSS
Do you recommend GE Monogram® ZISS420DMSS Side by Side Refrigerator?
Answer
Answer
Both sides of the refrigerator will just shut off for no reason. I had a new computer installed and... (More)
Answer
The CCD does not control temp - fan kicks on but temp only goes down - ultimately freezes everything... (More)
Answer
I have a built-in monogram series side-by-side refrigerator 36x42x48 bought in 2002. About every... (More)
Answer
The dispenser on my GE Monogram side by side will only dispense water. Neither the crushed nor cube... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
