Question about Tascam Dp-02cf Digital 8-track Recorder
Tascam dp02 when mastering it will let me set out in and out points, but is not mastering. I put the light on till it blinks run it through and let it set out. when I play back with the solid green light it did not take the master. I have used this function before, is there something I can do?
4 Suggested Answers
SOURCE: I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
Posted on Sep 15, 2009
  • 15 Answers
SOURCE: I've been exporting master tracks and now I've
If you NO LONGER NEED the songs/data in the FAT partition, you can delete the entire contents thereof in the manner detailed below. Note that these instructions were taken directly from the Neo manual.
1 With the transport stopped, from the DISK menu, highlight FAT REFORM, and press YES/ENTER.
2 A pop-up message appears.
3 Ask yourself once more if you want to erase all the data on the FAT partition. Press YES/ENTER to continue with the operation when a pop-up appears, or press NO/EXIT to halt the operation.
4 When you reformat the FAT partition, four directories (folders) named WAVE, SMF, BACKUP and UTILITY are automatically created. These folders are used for audio files, Standard MIDI Files (SMF) and backup data and system utilities, respectively.
...this will reformat and thereby EMPTY the contents of the FAT partition and create the 4 new, empty files as listed above.
THINK before you do this though, and I hope this helps.
Posted on Feb 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: on my tascam 2488 neo,
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Posted on Feb 20, 2011
Jun 11, 2009 | Tascam Music
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP02 - LOW VOLUMES!
Phantom power should only be used with a condenser/ribbon mic. If you're using a dynamic mic (like the one in the photo) you don't need phantom power. Also I run my mics and instruments through a mixer, then into the unit. Also if you're mixing your masters at a low volume, the CD will play at a lower volume. Try mastering at as high a volume as possible, avoid clipping of course. But get it as loud as possible while mastering. Then the master copy should be louder. I have a DP02 and found out it needs decent monitors to mix and master. That's all I've got.
Apr 15, 2009 | Tascam DP01 All-In-One Recording Package...
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
For Tascam DP02 can't record and listen
Assuming your PA is a Yamaha STAGEPAS (although I thought 500 watts per side was the biggest one you could get). Anyway, on your PA's panel you will have the karaoke machine(s) plugged into the CD ins (top of the panel), while closer to the bottom you'll see the 'monitor outs' L and R 1/4 inch jacks. These are where you'd run the L and R from the PA into your Tascam (or L alone for mono out). The monitor outs are line level and are good for independently powered speakers, recording equipment, mixers etc. Just avoid using any outputs labelled 'speakers'.
bd.
Oct 25, 2008 | Tascam DP01 All-In-One Recording Package...
Tacsam DP02
this generally means there is a short.
Apr 25, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Dp-02cf Digital 8-track Recorder Logo
184 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
