Thanks for reply. It is 1 in properties. I might think its different problem.
First time user of flash memory after I plug it in what do I do next?? help me understand this new memory system
I think you got it wrong, my friend. - the "MB/s" is the speed your flash is giving or taking data from your PC :) The actual storage capacity can be reviewed if you go to "My computer", press right click on the flash drive icon and then press "properties".
Feb 22, 2015 | Electronics - Others
When I send an email to someone and he responds with reply the email goes to another address. Thanks!
Have him check is mail settings - In Outlook Express, click on Tools, Accounts, Mail then Properties. Have him make sure his reply address is the same as his E-mail address!
YavacoTech
Apr 14, 2011 | Computers & Internet
My Asus Eee net book is stating that it has "Limited or no connectivity" even when the ethernet cable is plugged in. I changed out cables thinking it was it. My other computer works just fine on the...
Assuming that you have Windows XP, let's check some settings for the network connections. Click on start - settings - control panel - network connections. First we'll check the ethernet connection. Right click on local area connection - properties - choose Internet protocol (TCP/IP) - properties. In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically". Click on OK at both windows. Now we will chect the Wi-fi connection. Right click on Wireless connection - properties - choose Internet protocol (TCP/IP) - properties. In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Click on OK at both windows and check for the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Computers & Internet
Fuel mix ratio for poulan counter vibe 3400 chain saw; mix ratio
A different site that lists 40:1. http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/4a98e23d38cbda9b88256bf80015de57?OpenDocument
Oil mix is controversial. Some think more is better, todays saws run much faster and carbon up much quicker. Ask the mechanics at a local saw shop. I will wager they say 50:1 regardless of the age of the saw. Me too! The Echo site now says use 50:1 regardless of what is printed in the OM. It is your saw Mike; run what you want.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Cant copy movie to it
pls insert the micro sd card to ny phone and format it and then connect it to the computer and check the followings.
1) whether the usb is recognizing ur card
2) right click on the mass storage drive created under my computers and select properties
3)update driver
4) now try copying the movies.
it should delinately work
thanks and reply back ur experience
Apr 20, 2010 | PNY 2GB microSD Memory Card
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
Mar 12, 2009 | Canon Office Equipment & Supplies
Wifi connectivity problem......
Please try these:
Under device manager, click on wireless LAN then select uninstall or properties-driver tab-uninstall. Then restart your laptop. If this is not possible,
Using a different laptop, please go to pcsupport.toshiba.com or support.toshiba.com - downloads - portables - select model - show results - downloads - then please click on the latest wifi driver - download. Please select save and save that driver to a disc then run it in your laptop. Restart laptop then hope it works.
Thank you.
Sep 30, 2008 | Computers & Internet
Want solution
well i think pixel view also provides this option of tv composite!! u need to check its property and check for an online support for this thing ,go to intex website and look for its property then its good to do anything,but i dont think that pixel view doesnt give default as well,because for the composite thing u need different type of cables for different type of inputs!! so when it comes to pc most of the manufactrers prefer tv tunning by default!!if u want read this article
http://www.tv-cards.com/messageboard/viewtopic.php?pid=54136
hope i was of any help!!!thanx
Jan 29, 2008 | Computers & Internet
E-100 Serial Connection Question
Go to your device manager in your laptop/desktop, then click on modems, then click on communications cable between two computers, then click on the modem tab and change the speed to 115200, then reboot (it doesn't say you have to but you need to). Change the speed in the casio communications to 115k and then sync. Reply With Quote
Sep 05, 2005 | Casio Cassiopeia E-100 Pocket PC
12 people viewed this question
jasbo
jasbo
