Question about General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V
1/2 innch conduit as a inside diameter of .054 and an out side dianeter of .78 what is the wall thickness?
    President:
  • 497 Answers
Assuming the measurements you gave were in inches the wall thickness is .12 inches.
Posted on Sep 10, 2009
  • Greg Mills Sep 10, 2009
    protek youre almost correct, since its a tube you need to divide your answer by two to get the wall thickness.
    whoops im not even right, its .14in assuming the inside diameter was .54 and not .054.
    President:
  • 1,714 Answers
Did you mean .54? (.78 - .54 =.28)
Or 28 hundredths of an inch
    Sergeant:
  • 384 Answers
Your inside dimension is not correct.
  • ProHydroRace Sep 11, 2009
    Some on! .78" - .054" = .726" / 2 = .363" wall. Like I said the dimension of the ID is not correct!!
I need to purchase a 72" downrod for concord ceiling fan. Problem is the diameter is 5/8" (inside dimension) and can't find any that diameter. .everything is either 1/2 or 3/4
I'm an electrician and have to say that the down rods for every paddle fan I have ever seen / installed (in the U.S.) are common "trade size" 3/4" pipes. Here's a link to 72" Concord Downroads:
3 4 Diameter 72 Down Rod
You should be able to use ANY 3/4" electrical grade "heavy wall" conduit pipe (and drill holes as needed at ends) and paint to your liking. Or pay the $$$ for the Concord label
Sep 28, 2015 | Dryers
Where is the wiring for tail lights on 1980 caravan
No. They are running by the frame under the van for the rear lights. Drivers side. They run inside a ribbed conduit.
Dec 28, 2014 | Cars & Trucks
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
I have an Amana refrigerator ARS266VBW and I had a refrigerant leak how much refrigerant does this refrigerator require? Also will it stop up the captube if I use a refrigerant with leak stop?
The data for the refrigerant should be on the model/serial number tag. the total charge is typically around 6 ounce of R134 that is the only refrigerant that can be used. Any stop leak if very likely going to block the cap. tube the inside diameter of it is about the thickness of two stands of hair which you know aint very thick at all
Aug 09, 2011 | Amana ARS266ZBS Side by Side Refrigerator
My brake pedal wont go down it is hard i have 93 dodge caravan hydralic brakes i belive
There is a brake booster, adjacient from the brake pedal under the hood mounted to the fire wall. It is black and about 10" in diameter. the master cylinder for the brakes is mounted to it. there is a rubber hose that comes from it that goes to the engine. it is a vacuum hose, about 1" in dianeter. Check this hose and make sure it is in good condition and has a strong vacuum to it from the engine. If it does then replace the brake booster. It has a diaphram it in and it is broken.
Jul 02, 2011 | Chevrolet C1500 Cars & Trucks
I just fininsh a room in the attic and I want to put a baseboard electric heater. which is the best way to run the wire from the attice to basement? Thanks
Wow - You're looking at quite the job!! The wire needs to be protected inside the walls or at the least inside conduit along the outside of the house - but that wouldn't be too pretty. I suggest getting yourself an Electricians fishtape ( if you don't already have one ) and choose a point either inside a closet or in a visually hidden location you can drill through the floors and the walls to fish your romex through. If all walls are sheetrock, you may have to literally cut a channel into the wall ( use a good metal detector to find existing electric and plumbing so you can miss those ) , bury the wire, and backfill with plaster or sheetrock mud. Either way, have patience - it is a long road you're going down. The easiest way ( not the prettiest, or necessarily legal in your area ) is to run some conduit vertically along the outside of the building and fish your wire into it. Get some wiresnot to help reduce friction and simplify the pulling of the wire in the conduit.Punch your hole through the basement and attic walls and make sure you seal those holes real good with silicone. Check first with your local city and or county building code enforcement office for the legality of externally mounted conduit / wire.
Hope this helps!
Nov 10, 2010 | Heating & Cooling
I have a 50 gal State water heater. I need a blanket that will fit it with measurements of 57in tall and 66in wide. Any suggestions since most blankets are 48in
Unfortunately, virtually all mass-market water heater blankets are 48" wide. One option is to buy a 32 sf roll of R13 ComfortTherm wall insulation (15" wide) and install in four segments. Unlike regular wall insulation, this product is sandwiched in plastic, making it much easier to handle and install (and neater) than kraft-faced insulation. It's made by Johns Manville and available at Lowes for about $9 (JM product number B011, Lowes item #44026). You'll need a suitable tape for the seams.
By the way, when calculating blanket width, you must add insulation thickness (times 2) to the tank diameter. My heater is 20.5" in diameter, so for 3.5" wall insulation, the effective diameter is 27.5", so the circumference is about 86".
Mass market blankets are 75" wide, and come in 1.5", 2" and 3" thicknesses. These can handle tank diameters up to 21, 20 and 18 inches, respectively.
Nov 04, 2010 | Thermwell Water Heater Blanket
Eljer Flushmate Floor Mount Floor Discharge 1.6gpf rim impaction
try putting KLR or even vinegar down the tubes. also using a stiff brush and klr or vinegar, scrub the jets from inside the bowl to help remove and soften it up. your coat hanger may only be compounding the problem by packing it in harder and tighter. when you get it running again, and it is a good one, make sure and put a bowl cleaner that also softens the water. can't say brand names..... but there are several good ones.
Feb 03, 2010 | Eljer Aqua-Saver 12" Two-Piece...
BELL JOGGER HANDLE
(800) 456-2355 is the customer service number for Bell. Unfortunately, the stroller only has a 1 year warranty and no replacement parts. I won't be buying their products again.
Oct 29, 2007 | Bell Sports Scout Jogger
General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V Logo
229 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
