Question about Garmin StreetPilot c510 Deluxe GPS Receiver
Sighn low battery comes on and screen cuts off.Is
Sighn low battery comes on and screen cuts off.Is there a battery I can replace and how?I have Garmin gps c330.
    Scholar:
  • 129 Answers
Hi
the battery is available in the market.
or you can log on to the alibaba.com ,a global rechargeable battery online selling site .
Thank You
Posted on Sep 10, 2009
Tip
Simple: First thing is get a test light, hook the test light up to the negetive...
simple: First thing is get a test light, hook the test light up to the negetive side of the battery. take your test light and touch it to the positive side of the coil ( should have a + sighn on it ) have someone turn the key on and look for the light to come on. if it dosen't then check for blown fuses or brokenwires to positive side of coil. If light does come on move to next step..
now hook your test light to positive side of battery, touch your test light to the negetive side of the coil ( it should have a - sighn on it, then have an assistant spin the engine over if the light blinks rapidly and still no spark from coil then the coil is bad. if there is no blinking light then the ignition module or points are whatever controls your trigger to the coil is bad.
on Jan 02, 2010 | Motorcycles
Tip
How to check for a no spark condition on older vehicles with distributors
on Dec 30, 2009 | Chevrolet 1500 Cars & Trucks
My ipod model a 1285 keeps turning itself off why
iPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Jan 22, 2013 | Apple iPod Audio Players & Recorders
BATTERY GOING DOWN TO FAST AND A LIGHT ON ALL THE TIME LOOKS LIKE A SOUND SIGHN
How old is the battery? "A LIGHT ON ALL THE TIME LOOKS LIKE A SOUND SIGHN"? Can you explain?
Jan 08, 2013 | Computers & Internet
Door open sighn comes on display drum does not
take out door switch and tape the two wires together, if the washer works fine this way, then the door switch is bad. if the door switch fails it cuts electricity off to motor.
Jan 14, 2010 | Whirlpool AWM6141/1 Front Load Washer
1992 Mitsubishi Eclipse battery seems to drain & idle high/low
check for vacuum leaks in failing hoses and loose fittings
May 26, 2017 | 1992 Mitsubishi Eclipse
Battrey voltage low
The only battery in a desktop is the CMOS battery. This is a small round battery, looks like a watch battery and it is on your motherboard. The battery keeps a small amount of electricity going when your computer is turned off so that the clock and date can be kept current. If you take the cover off of your PC you will see it on the mother board. Write down the numbers on it and you can find another one at Radio Shack.
Dec 24, 2008 | Computers & Internet
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
