Question about Konica Minolta magicolor 2400 Laser Printer
Magicolor 2400W loose parts
While clearing a jam, a user dislodged or found dislodged 2 small parts (apparently from the right side of the drum cavity): a coil spring about 1 inch long including attachment loops, and a black plastic part, approx 1 inch square with an obvious spring anchor on one edge and a foam pad glued to one side. Can you describe where these should be reinstalled?
  • bvb Sep 10, 2009
    Solved. The parts fell off the drum.
How to calliberate the developer in ineo 363 konica minolta copier
Must first Admin setting/ system settings/expert setting FOWARD upper right corner "Drum dry". Press START
Second Service mode/ counters/ life/ page 2 CLEAR Developer use time. Touch END PWR off the machine.
THIRD:
Remove the image cartridge. Right side of machine BE CARFUL THER IS A SMALL ELECTRICAL CONNECTOR HIDING UNDER NEATH A SMALL PLASTIC COVER ONE SCREW REMOVES IT WHICH MUST BE REMOVED BEFORE THE IMAGE CART IS REMOVED IF YOU DONT YOU WILL BE SPENDING A LOT OF MONEY GETTING THAT FIXED.
Fourth: Dis-assy. Cart and replace the developer and also replace drum both should be replaced at the same time.
Once done re-insert cart CONNECT THE CONNECTOR!!!!!!!!
Then Power up machine go to service mode/ image process adj./and then Grad adjustment.
DO NOT RUN ANY COPIES or PRINTS UNTIL THE ABOVE IS DONE OR YOU WILL HAVE TO RE{PLACE THE DVELOPER AGAIN.
Really may want to have a technician do the above
May 19, 2014 | Minolta magicolor 2400W Laser Printer
Remove lines in print from Minolta Magicolor 2400w
check the fusing unit the hot part where the paper comes out? is the line a certain color replace that image unit.
Sep 22, 2012 | Minolta magicolor 2400W Laser Printer
How do you clean the drum on a Minolta magicolor 2400W Laser Printer?
HI, I think you would be wise not to clean the drum, other than removing the toner dust. If you have problems with print quality, firstly check each cartridge in turn and see if the rubber toner roller is smoothly covered in the appropriate colour toner. If all is OK here, then empty the dust container. The dust container is in the back side of the the transfer band (drum), on the right hand side you will find an area where there is tape applied. Remove the tape to reveal the hole into the dust collector. Take care as there is usually a great deal of old toner in there, so it is a good idea to have a container at hand when you empty it. hen you have emptied it, you must of course reseal the hole. I have found the best sealer for this is the self adhesive alluminium tape which one can buy in any hardware shop.
Hopefully therafter all wil be OK.
Oct 20, 2010 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
MINOLTA 2400W
try installing it again, first turn off the printer.and then turnit on again. if that wount help, under the cartridge in left or right side, there is a small fuse, you can testit with tester, is it OK, if not, by new fuse
Jan 22, 2008 | Konica Minolta magicolor 2400 Laser...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
