Question about Smith Corona Wordsmith 200 Typewriter
Repeating Key I work at a school. The first time I turned the typewriter on it keeps typing one letter (a "Y"). I tried prying up on the "Y" no luck. I took out the daisy wheel and ribbon - No change. It's very humid in our school. Could this be the problem?
  • Smith Corona Master
  • 3,594 Answers
Humidity could be a factor but more likely something got vspilled in the keyboard ans is shorting out some ofthe traces, you need a tech to open and clean or replace the velum.
DickyO
Posted on Sep 22, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
When i turn it on it will beep every letter i enter but won't type anything it is a swintec model-600
try putting the machine in test mode. You can do this by holding down the margin release key while turning it on. Keep holding it down until it starts typing by itself. Then turn it off and on again and see if it works.
Mar 07, 2009 | Swintec 7040 Typewriter
Keys don't match what types. Letters type other letters.
Check the connectors from thr PC board to the keyboard, if they are OK tren try this hold the code key press and release the "L" key type 001 release thecode key. If this works you need a keyboard to repair it'
DickyO
Jan 24, 2009 | IBM 3500 Typewriter
Ibm wheel writer 6
Hello, You have the lang. button on. Code L and that should turn it off. Cherie'
Jul 26, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
56 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
