Question about Konica Minolta magicolor 2430 DL Laser Printer
Magicolor 2400W loose parts
I have a Magicolor 2400W printer. While clearing a jam, the user dislodged 2 small parts (apparently in the right side of the drum cavity): a coil spring about 1" long including attachment loops, and a black plastic part approx. 1" square with an obvious spring anchor on one edge and a foam pad glued to one side. Can you describe where these should be reinstalled? Without the parts, the printer shows no errors but simply never prints the document after downloading it.
  • bvb Sep 10, 2009
    Solved. The parts fell off the drum and were easily reattached.
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Remove lines in print from Minolta Magicolor 2400w
check the fusing unit the hot part where the paper comes out? is the line a certain color replace that image unit.
Sep 22, 2012 | Minolta magicolor 2400W Laser Printer
Konica Minolta 2400w paper jam at top back side. Several small pieces stuck and I can't reach them. Is there a way to disasemble?
yes there is a way, but if you do it yourself there are more chances that you will break it.so dont try it yourself.call concerning technical service rep.
Jun 10, 2010 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
136 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
