Question about InFocus ScreenPlay 5000 Multimedia Projector
Can't obtain images from computer, can not find installation icon, would like instructions on proper cable connections
  • 2,237 Answers
All you need is vga cable from monitor out to vga in on the projector. or dvi to dvi. the usb is for control, not for image.
Posted on Sep 10, 2009
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
Tip
Setting up a Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network. Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/ IP) address automatically, so your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each other across a network, such as the Internet.
First, find out which Windows operating system your computer is running.
You can find out by clicking the Start button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router. The next few pages tell you, step by step, how to configure your network settings based on the type of Windows operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/ IP line for the applicable Ethernet adapter. Do not choose a TCP/ IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/ IP appears by itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files. Check for the files at c:windowsoptionscabs, or insert your Windows CD-ROM into your CD-ROM drive and check the correct file location, e.g., D:win98, D:win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dial-up Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/ IP) is checked. Highlight Internet Protocol (TCP/ IP), and click the Properties button.
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the Classic interface (where the icons and menus look like previous Windows versions), please follow the instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon. Then click the Network Connections icon.
If you would like more information on setting up your connection, please post your questions and I will surely respond.
Also for any clarification, you can email me at titilayosodipe@live.com
Best regards.
Sholly-NG
on Jan 07, 2010 | Computers & Internet
Tip
Setting up a Router
in product damage.
Overview
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
If you would like more information on setting up your connection, please ask me a question.....
Cheers.
on Jan 03, 2010 | Computers & Internet
On button flashes yellow but wont turn on
unplug the power cable for 10secs. press the power button while its unplug to remove all the electricity in the cpu. connect the power cable and then press the button. if you hear a beeping sound when you turn on the cpu, you have a problem with the motherboard. if no beeping sound, check the 4 diagnostics lights at the back of the cpu, advtrbl5.jpgMemory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer.
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance
advtrbl6.jpgA possible expansion card failure has occurred.
  1. Determine if a conflict exists by removing a card (not the video card) and then restarting the computer.
  2. If the problem persists, reinstall the card that you removed, remove a different card, and then restart the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Incompatibilities" in the Owner's Manual).
  4. If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
advtrbl7.jpgA possible video card failure has occurred
  • If the computer has a video card, remove the card and reinstall it, and restart the computer.
  • If the problem still exists, install a video card that you know works and restart the computer.
  • If the problem persists or the computer has integrated video, see "Contacting Dell" in your Owner's Manual.
advtrb16.jpgOther failure has occurred
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
How to look at the pictures i took in my computer i need to know what to click on or how to hook it up
Download images to your Computer
Before connecting your ViviCam 3350 to your PC for the first time you must first install the Twain driver first.
After the driver software has been installed, your still images and movie clips can be transferred to your PC using the USB cable. You will know that the ViviCam 3350 is ready to use when two icons appear on your desktop. The “ViviCam 3350” icon is used for downloading still mages to your computer.
The “PCCam” icon is for using the live video feature of the ViviCam 3350.
477c519.png Connect your camera to your PC using the USB cable. The camera will beep once, indicating the connection is established. The camera installation process will be completed the first time the camera is connected to your PC.
Transfer images to your PC
To transfer images to your PC connect the camera to your PC.
Double click on the desktop camera icon:6a84e21.png
Apr 09, 2010 | Vivitar ViviCam 3350 Digital Camera
Tip
Full details on how to set up your Wireless-G WRT54G Router
in product damage.
Overview
the Router.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
Connections icon.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
on Jun 28, 2008 | Linksys Wireless-G WRT54G Router
Changing bulb
Upon setting up your equipment it is very important that you turn on the projector first. You will see a blank projection image, now turn on the computer, (confirm your cables are connected properly). When using a lap top computer you may need to disable your computer's display screen. First locate the "function" key at the top of your keypad that reads "LCD", "CRT" or it may have an icon that resembles a computer monitor. By pressing the "FN" key and the corresponding "function" key you will be able to obtain the image from the projector only. This is known as "toggling" the image.
for more info check this link http://www.avispl.com/service-support/projector-troubleshooting.asp#2
Sep 06, 2008 | Sanyo PLV-Z2 Multimedia Projector
Netgear MR314
in product damage.
Overview
the Router.
Connections icon.
Jul 05, 2008 | NetGear MR314 802.11b
My router stopped working
Try to create a new connection.
in product damage.
Overview
the Router.
Connections icon.
Scanning a document
The full version All-in-one software need to be installed to scan.
However, you haven't informed anything about the version of operating system that is installed in your computer. However, please follow the below given instructions to scan.
For XP:
Place a document on the scanner glass and check if the USB cable is connected to the computer correctly.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
For Windows 2000/Me/98
2.Click Start then Click Programs then Click Accessories then Click Imaging.
3.From the Imaging application, click File, and then click Select Device.
4.Select the HP all-in-one device from the TWAIN source list.
5.Click File, and then Acquire Image.
For Vista:
Scanning with Paint:
1. Click Windows.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
You can use all the above given instructions to scan.
If the full version All-in-one software is installed, please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpu04515
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Hope the above information will be helpfull.
Wish you good luck!
Regards,
Lawrence
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
InFocus ScreenPlay 5000 Multimedia Projector Logo
62 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
