Question about NetGear FSM750S Ethernet Switch 48 x 10/100Base-TX LAN 2 x GBIC Ethernet Switch (FSM750SNAFT)
Fsm750s 48 port - we had ports 9,10,11,12 go out in a storm - can they be repaired? power on/off didn't reset - going into the Netgear via IP and disabling and enabling also did not work
  • 339 Answers
Unfortunately, nothing to be done other than replace it if you need the ports. You could in theory replace the chip or chips that got burned up but it would probably not be worth it and it it's an ASIC(likely) you'll probably not even be able to source it.
Posted on Sep 11, 2009
Default password
The default password is blank (i.e., leave the password field blank).
Nov 18, 2013 | NetGear ProSafe GSM7248 48-Port Gigabit...
How do i connect to apples time machine?
You can manually configure the time machine to accept wireless signal from the router or extender. If you setup WEP on the router or extender, make sure you setup WEP on the time machine as well.
For instructions in setting up wireless settings of Time Capsule click on this link -->>
http://www.apple.com/timecapsule/wireless.html
Hope this works for you.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Unable to detect my Netgear Gigabit smart switch GS748T via Smartwizard discovery. Earlier have tried reset the switch to factory default but to no avail. Pls help.
First, make sure your switch and PC are in the same broadcast domain/subnet, and that there is a DHCP server in operation.
Second, make sure you are following the "factory reset" procedure correctly (http://support.netgear.com/product/GS748Tv1).
Third, check your version of Smartwizard Discovery, and download a newer version if one is available. I think the latest version is 2.05.05 (download from http://support.netgear.com/product/GS724Tv2).
Sep 28, 2011 | NetGear ProSafe GS748T 48-Port Gigabit...
I am trying to configure a netgear switch (48 ports)but everytime I configure the static IP address for the switch, it keeps defaulting to a different IP address once it is powered down. I have also tried...
I'm not too familiar with Netgear switches, but if you told me you were having this issue with a Cisco switch, I'd tell you that after you change the IP address you need to save your configuration to NVRAM using the "copy run start" command. A Cisco switch will look to start using the configuration stored in NVRAM when it is booted. Changes are made to the configuration in RAM and are lost when reboot occurs unless they are first saved to NVRAM. Perhaps there is a similar command for the Netgear switch. Hope this helps
May 26, 2010 | NetGear 48-PORT 10/100/1000MBP SWITCH...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
Unable to factory reset - all port lights stay on with just power cable plugged in
All port lights showing on a router indicate a bad control board in the router. I'd say it's toast.
May 25, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 v6 I would like to host Nascar races & need to open TCP Port 8590 to allow this to happen . Can anyone help me ? Thanks Lenny
You need about 3 pieces of information to make this work; the machine that's going to serve's IP address, the password to your router, and a machine on the network.
You can let the serving machine obtain an IP address automatically, but if it changes you will have to reset your server IP address all the time. So, for fun, give it an address in your IP range, generally 192.168.1.x. Pick a number like maybe 250. Then, log into your Netgear (192.168.1.1) and use admin and the password to get to the router web page. On the left tab, go to port forwarding, create a new custom service, and put in 8590 and the IP address of the server.
Once you apply it, it will show up in the table and you'll see what port, a name, and the internal IP address 8590 goes to.
Carl
Mar 01, 2009 | NetGear WGR614 Wireless Router
Netgear switch GS748T smart switch needs reboot very frequent
(Answering a six-year-old question...)
From the description--especially the part about having "spanning tree" disabled--the first thing that I would do is look for network loops. STP/RSTP ("spanning tree") detects these loops, and disables ports to prevent packet storms. If that is the problem, enabling STP should clear it up--but you also want to make sure you want those loops in the first place.
Dec 02, 2008 | NetGear ProSafe GS748T 48-port Gigabit...
Unable to print through the print server
First, make sure that you can print with the printer connected directly to your computer using a usb cable.
- Make sure the printer driver is installed and you can print with a direct connection
- Get the print server's IP Address, NetGear should have already provided you with this info.
- If your'e using windows xp, go to control panel > printers and faxes
- Right click on the printer icon and go to properties
- Click on the PORTS tab
- Click on ADD PORT
- Highlight Standard TCP/IP Port then click on New Port
- Click next
- Input the WGPS606 IP Address
- Print a test page...
-hope it works!!
Apr 09, 2008 | Office Equipment & Supplies
WAN light off on router
Hi Bootstrap,
Try a new cable. I know it sound strange, but I have had some work in one port, and not others.
If you still don't get a WAN link light, try resetting your router. We don't know what Netgear you have, but usually there is just a small hole where you press in with a paperclip, or pencil, and hold it in for 30 sec. Lights should flash when you release it. Connect your PC to one of the LAN ports, with the router powered up, and power up your PC. On your PC, go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router, or your router is not issuing an IP, thru DHCP.
Make sure your router basic settings is setup for your Internet connection type, i.e. DSL or cable. If all that fails, can you return the router? Is it new? What model Netgear is it? The WAN port not working does make me think it may have been damaged by a power spike. Have you had any lightning storms lately, or power outages?
Let us know if any of that helps. Or give us more info and we can see what else we can find.
Jan 13, 2008 | NetGear WGR614 Router
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
