Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Emerson microwave MW9111 will not heat- all timers & clock work fine- just won't heat . is this a fuse? if so, where is it located? (I have replaced fuses in other microwaves.)
  • 1 more comment
  • cherylshimp Sep 10, 2009
    sorry- was mowing... when it runs, it sounds normal- like it's cooking. when you take the item out- it's the same temp as when you put it in. Have read everything from "door sensor" to "magnatron". Everything else on microwave works, just will not heat, even though it sounds like it's heating normally. If it is a fuse, where is it located, once I take the panel off?
  • William Miller
    William Miller May 11, 2010
    It's not going to be a fuse. If the inside light, intenral cooling fan, and turntable do not ALL work when you try to cook, then you have a bad door switch or door switch mount. Pulling up or down on the door while you try to run it may make it start working, thus hsowing you where the problem lies. If these all do work, it's most likely a bad connection at the magnetron, a bad magnetron, or a bad high voltage rectifier diode. Whether it's louder or quieter than usual can provide clues. NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice. William E. Miller prototech@usa.nethttp://www.microwavedisplay.com
  • bulldogchief
    bulldogchief May 11, 2010
    Is it making any sounds when you run it? Does it sound like an angry swarm of bees? If so, then most likely the magnetron has failed. If you are not hearing any sounds like this then, maybe, it might be the fuse.
    Sergeant:
  • 269 Answers
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
  • 388 Answers
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Posted on Sep 10, 2009
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Microwave too much steam won't cook
If there is no heat, then it's probably a defective magnetron.
May 08, 2012 | Emerson Microwave Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
Hi, I have an Oster OMW1199 microwave that will not heat food. The light turns on and the timer works, but no heat.
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Aug 28, 2011 | Emerson Fans Emerson MW8115SS Microwave...
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Jul 09, 2011 | Emerson Microwave Ovens
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My microwave doesnt heat up,
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Their contact information will be in your owner's manual.
If for some reason you do not have your owner's manual, please reply back with your brand and model number so we can help you.
Dec 22, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
809 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
