1998 Dodge Grand Caravan Logo
Posted on Sep 10, 2009
Code 1494 I have a 1997 Mitsubishi Eclipse 2.0 with a service engine code of 1494
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1924
Points
10
Did you mean p1494? If so then its your evaporative emission ventilation switch or a mechanical fault, probable causes:
  1. Evaporative Emission Ventilation Solenoid failed
  2. An open or short circuit.
  3. Vacuum hose clogged.
  4. PCM Failed
Check the following:
  1. Check the following connectors: A-109, B-76, B-63, A-107. Repair if needed. If its ok then check:
  2. Check the harness wire between the Evaporative Emission Ventilation Solenoid connector. If its ok then:
  3. Replace PCM
This information was retrieved from AllData :
I need diagram for firing order for 2007 Mitsubishi Eclipse Spyder 2.4L. Changing O2 sensors and need for guidance on placement.
The 4G64 (2.4L) engine is an in-line four cylinder engine. The cylinder numbers are assigned as 1-2-3-4 from the front of the engine (timing belt side). This engine is fired in the order of the 1, 3, 4 and 2 cylinders.
Feb. 27, 2009
Spark Plug Order ' Mitsubishi Eclipse 3G Club
Pictures
https://www.google.com/search?q=firing+order+for+2007+Mitsubishi+Eclipse+Spyder+2.4L
Strictly speaking you have two fuel / air sensors in the manifold for the catalytic converter and two O2 sensors after the cat.
Details here
https://www.google.com/search?q=2007+Mitsubishi+Eclipse+Spyder+2.4L+Replace+o2+sensor
buy original equipment manufacturer sensors (OEM). Their job is important to engine management.
1helpful
2answers
2000 Mitsubishi Eclipse Problem TCL
2 concern for you when check engine light comes on your TCL (traction control) is disabled,so you get the light,and if TCL is disabled so is the ABS (anti lock brakes) you first step is get the Check engine light code,If it was just a TCL light on the ABS code will need to be gathered,You need a scan tool
2answers
Multiple erroneous diagnostic code readings.
Contact a Mitsubishi dealer for advise , could need a new ecu , hard to say without seeing vehicle
2answers
2002 Mitsubishi Eclipse Service Engine Soon Light On
codes p0402--p0403deal with exhaust gas recirculation control circuit malfunction as well as the performance of this circuit check connections
Service engine soon light on 2003 mitsubishi eclipse spyder
If you want to fix it yourself take it to an auto parts store they have code readers that diagnose what set it off. If your not sure about it take it to a mechanic.
2001 eclipse fuse box diagram
Your car already has a fuse box diagram located on the inside of the fuse box lid. However, in case its missing from there, follow these two links and you will know everything about fuses:
1. http://mitsubishifuseboxdiagram.blogspot.com/2012/09/fuse-box-mitsubishi-eclipse-diagram.html
2. https://tearstone.com/2000-2002-eclipse-service-manual/
2helpful
2answers
Picture diagram for 2000 eclipse spark plug to distributer
According with engine sizes, check this for 2000 Mitsubishi Eclipse GT 3.0 liter SOHC V-6
or 2000 Mitsubishi Eclipse GS 2.4 liter SOHC L4
Hope helps.
Self diagnostic test codes
anytime you do the self-diagnostic you will almost always get those 2 codes.
12 - direct power input to the PCM has been disconnected within the last 50 key-on cycles
55 - End of error messages
Mitsubishi eclipse 2001
Drive cycle is performed by driving the car at hiway and city speeds over a few days and perhaps 50 miles or so, if the system detects the same issue after a few days of driving and completion of drive cycle then the check engine light will come back on.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
