Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RF Tuner I need the part number of the RF Tuner for a D52W20 RCA 52 inch TV. I was going to just get a replacment end but it broke to were it was inpossible to do that. If you know a website and could leave a link that would be great. Thanks
  • 1,030 Answers
The tuner for this unit is a rca 264658 componet is nh101
Posted on Dec 10, 2007
Yea i have a 52 in rear projection hdtv and i went to move it and the cable piece itself broke off and now the tv power light blinks three times and jus shuts off how can i fix that
the cable connector being broke more than likely has damaged the tuner. sometimes the tuner can be rebuilt depending on the damage. since the set is shutting down there may be more damage. if the set stayed on you might be able to bypass it using vcr. the worst case the small signal board might need replaced that cost aroun 300
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The coaxle broke where you put the cable line on
The coaxial connects inside the set to the tuner. It needs to be resoldered in to the board & secured on the outside to the tuner. Its a quick fix at any tv repair shop. Unless u tried stick something inside & damaged internals of tuner
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tuner replacement on RCA D52W20
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch RCA Screen TV, there was a thunder storm and it
Check your AC fuse first it will be on board that has your cord pluged into it, if its ok ck odd looking fuses next to your tuner if it is opened set will not come on.
Dec 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken Cabel Connector RCA 52 HDTV
depend on how badly damage it might be.. as a tech i replace these all the time.. if you can solder it might be possible.
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
please recheck your model# it should read HD52W59YX39 if this is the correct model the part # is 271850 cost $166.99
changing this part will cause major alignment
the part can be replaced - the RF part # is 215543 for $4.39 or the tuner can be changed part # 268904 cost $30.39
on another note if you are using a cable box or sat box there is no need to repair the rf hooke the tv up with rca plugs
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
