Question about Marshall Music
My marshall valvestate 100w combo makes a high pitched noise, similar to feedback but not, almost immediately after switching on. Is it maybe that the preamp valve needs replacing? If you tap the amp it usually increases, the only way to stop it is to turn it off. It's sometimes not too bad and playable, but always eventually starts to whine increasingly loudly.
  • Marshall Master
  • 5,603 Answers
One of the tubes COULD be microphonic.
Take back off and use a pencil to lightly tap each tube to see if one causes noise.
Posted on Sep 10, 2009
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
Hey, the clean channel on my Marshall 250dfx Combo amp isnt working the distortion and everything is working as normal, but the clean channel makes no sound at all, i was wondering if you can help?
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Oct 18, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall MB 150 when on classic channel at 2.5 volume it emits a beat like a drum beat approx every .5 sec
There are a lot of reasons your amp could be "motorboating" That is the term given to a low frequency oscillation. Be it only a half second it is still an oscillation. Electrolytic bypass caps are suspect most of the time. I would highly doubt there is a feedback problem with the amplifier circuits due to the fact this probably just started happening. Grounding on power supply caps also can be a big suspect. There could be a cracked solder joint on one of those components that is causing a ground loop which in turn will cause your parasitic oscillation of a 0.5 Hz.
Dec 17, 2009 | Marshall Amplification Marshall MG250DFX...
One of My speakers does not work, When I switched the speaker wires the problem followed. I believe maybe a blown channel. """please help"""
Yes, one of the power amps has probably failed. If the channels are seperate, then another possibility is a bad input connector. These do get broken when cables are tripped over.
Nov 08, 2009 | Marshall Amplification Marshall MG250DFX...
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
Music Logo
514 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
