I have a Phillips 55pp93
I have a problem with the convergence in the red channel, the intresting thing is it moves in the Y axis but not in X. Is this a typical failure mode for the convergence amp??
    Novelist:
    Champion:
  • 232 Answers
Eryn, yes it is, the convergence chips and possibly a few precision support resistors have failed, get them replaced and you`ll be good as new, Questions ? email me back, Happy Holidays, BMW Rider
Posted on Dec 10, 2007
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
I have a 55pp93 that has colored hazes around images and words.
change the coolant in the CRTs A common problem with phillips rear projection is that the coolant becomes congealed and then the set will have dim colors and very hard to focus
Jun 12, 2009 | Philips 55PP9363 55" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red will not converge even after I replaced both IC's. Please Help ASAP!
I have a phillips in my office like this. There are a few things to check. Check the resistors around the red convergence ics it is probably open resistor or resistor fuse take your time and check all the resistors.In rear cases it could be the surface mount ics on bottom of convergence board i hope that is not the case.
thanks doctor video leading edge electronics
May 08, 2008 | Philips 43P8341 43" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Menue and multipoint
I fixed this tonight -- it was the convergence amps, which I purchased for $20. Thought it was the convergence board at first but it turned out to be the amps, which commonly fail after 3 years or so.
Dec 17, 2007 | Philips 60PP9202 60" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
