Question about Whirlpool Dishwashers
Need a operators manual for whirlpool Model#DU1145XTPBA dishwasher
  • 33 Answers
Go to this ste and click on GET THIS MANUAL to downlode a coppy.
http://tiny.cc/HVFry
Posted on Sep 12, 2009
Where is the whirlpool du1145xtpba drain pipe located
It is located at the rear of the dishwasher and it connects to the garbage disposal, when it drains you can see the water entering the disposer if you shine a flashlight in the opening.
Jan 24, 2012 | Kenmore 17459 Free-standing Dishwasher
Whirlpool Quiet Partner II Dishwasher Model DU1145XTPBA Mine is all black, I would like to get the stainless steel door insert if available. Can you assist me
absolutely-- Go to http://www.applianceart.com
They have the stainless inserts available. They appear to be on sale now too! You can call these guys and get assitance if needed when placing your order. I am including the link for you to the panels themselves below. Hope this helps.
http://www.applianceart.com/Stainless_Steel_Dishwasher_Panel_p/10847.htm
Sep 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Jun 21, 2011 | Whirlpool Dishwashers
Our Whirlpool dishwasher, DU1145XTPBA, has almost quit cleaning the dishes. It started with dishes on the top rack. My husband was told by rep to replace the top unit. That did not help at all. Now the...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Have a Whirlpool Quite Partner II DU1145XTPBA 1 1/2 old just stop working no lights will come on at all. There is standing water in the bottom. We have replaced the thermal fuse and still nothing. What...
Re-verify the thermal fuse.
If the new wire that came with the fuse was not used the fuse will blow again.
Check the door switch for continuity.
The power to all parts goes through the door switch first.
Open the wire terminal box and check the incoming power wires for good contact.
The drain pump may have a blockage in it as well.
Jul 31, 2010 | Dishwashers
I have a whirlpool dishwasher that won't start even though there is power going to it. I was told by someone at Lowes ro shut the breakers off for 15 minutes and that would no doubt fix the problem. it did...
Check there is no water in the tray under the machine.
There will be a switch that turns off everything if there is a possible leak - so may be that. Just blot up any water and try again.
If there is a slight leak - trace it.
May 02, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whines when in operation
Sorry, but I don't have a solution, but I share this problem with my Whirlpool Model DU1145XTPBA, which I assume is essentially the same model. It started a couple of weeks ago, and it's about to drive me nuts. The whine is more or less steady, and quite loud, as long as the motor is running.
I dread having to spend the money on a new motor/pump assembly, plus the joy of replacement, and I'm hoping there is an easier, simpler, less expensive alternative.
Aug 19, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Dishwashers Logo
177 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
