Question about Epson Stylus Pro 9600 InkJet Printer
Horizontal Banding Issue only on Polyprop Banner material
We have an Epson Stylus Pro 9600 which prints fine on regular weight material, but always leaves horizontal lines on the print when we try and print with a heavy-weight banner material, in this case TAL IJ-B Polyprop Banner 300. Should we increase the distance between the heads and the material when printing?
  • info25636 Sep 17, 2009
    We actually managed to get around this by simply telling the machine to treat the stock as regular photo paper.
Error 0D050000
Check the cartridges. either any cartridge is dry or empty
Dec 30, 2013 | Epson Stylus Pro 9600 InkJet Printer
Horizontal lines running through my prints.
Try printing at the slowest or best setting for a while. You would be wasting a lot of ink if you do head cleaning several times.
Feb 12, 2010 | Epson Stylus Pro 9600 InkJet Printer
Banding
If your print head alignment is good, try printing at the slowest setting for the mean time until the banding is gone.
Jan 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Different ink settings banding
Try doing a printer head alignment, sounds like the printer heads are overlapping causing the banding.
Screen colors also never match perfectly to the print either, whist your monitor can produce millions of colors, the printer can only do some many.
Aug 30, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Horizontal banding
have you tryed to update your drivers on the printer
Dec 15, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Pro 9600 InkJet Printer Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
