DISPLAY BUTTOM FLASHED 10 TIMES DISPLAY BUTTOM FLASHED 10TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL# 9726928
  • 10,594 Answers
I just replied your question as follows..
Blinking LED shows an error code in TV and 5 times blinking shows white balance problem.
In my opinion, TV requires Screen volt adjustment that should be done by qualified tech.
If you have experience of electronics stuff or TV repair, I can guide you to fix this problem.
Thanks.
Posted on Sep 10, 2009
I have a samsung Un46D6000 SFXZA The red light on the front blinks 10times. Then steady and 10 blinks.. repeating. I replaced the power supply and the t-con and it is still doing it. With replacing those,...
The power supply is inside the TV, SO YOU MUST HAVE REPLACED THEPOWER CORD. The problem is most likely inside the TV. It is probably 4 or 5 capacitors that need to be replaced. If it is out of warranty, take it to a service center.
Nov 26, 2014 | Televison & Video
Sony LCD KLV32BX35A 5x Blinking Problem.
When an LCD TV turns on for a little while, and then dies, problem usually capacitors or IC's in Power Supply section, specifically diode bridge in Inverter board, or T-Con timing board.
Jul 17, 2014 | Sony KLV-32BX300 32 inch Multi-System LCD...
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Video goes off led blinks 5 times then video returns, audio ok
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. For more details, check this.
Jan 08, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
DISPLAY BUTTOM FLASHED 5 TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL#...
Hi
Thanks for using FixYa. You need to check the horizontal and vertical output wave form at the high side of the deflection which should be a normal horizontal/vertical pulse respectively. Now check the HV output transistor on all three elements and also check the regulator transistor which might have short. Replace the parts/diodes which are gone bad and can be easily replaced. You can order these from the following link --
Projection TV spares parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | Televison & Video
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Tv blinks on and off ever 5-10 seconds and display will not turn off
sounds like the sets motor boating from the power supply like a bad regulator IC or a bad capacitor.
Aug 16, 2006 | Sony KV-36FS16 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
