Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Settings for low and high speed screws for carb for husqvarna 136
    Sergeant:
  • 302 Answers
Turn them both in , gently, till they bottom out and then back them out 1 1/2 turns. This will get you real close and then fine tune them from there. hope this helps.
Posted on Sep 10, 2009
Testimonial: "thanks is working fine now with some fine tuning"
Husqvarna 128LD weed eater wont start - replaced spark plug - carb - ????
If you can confirm that you have spark then you basically have a fuel delivery problem - carburetor.
If you installed a new carb you have to set it up , with the idle adjustment , and the low and high speed mixture screws. You just do not insert the carb and expect it to work.
Aug 29, 2017 | Husqvarna Garden
Adjustments carb zama
1.5 out each usually... Try it around there I guess
Aug 06, 2014 | Husqvarna 128 LD Weedeater
Husqvarna 445 starts and stops running
check carb settings. turn low speed adjusting screw all the way in then turn it out about 1 1/4 turns out. repeat with high speed screw. when running readjust low speed until proper idle and high speed for proper high rpm .
Nov 24, 2013 | Garden
Have a 137e husqavarna saw put new carb on and just fires and dies. Any help would be appreciated
Try when idle to adjust the carb settings.There has to be 2 screws to adjust the low and high.The low is for when the saw is in low at speed or when is not in use for cut.When you pull the handle to start cut then the adjust the high one at max speed.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On the husqvarna se266 carborater, what is the low and high screw settings or how many turns is the screws supposed to be at?
Initial setting for a Husqvarna; "H" and "L" screws at 1 turn CCW form lightly seated. Then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 22, 2010 | Garden
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 435 wot run at full speed runs at idle fine and looks like u need a special tool for the high low carb adustment
On that model the low adjustment may be factory set, and the adjustment screw is replaced with a roll pin. The high adjustment has a cover on it that can be prised free revealing the screw beneath. Turn screw all the way in (clockwise) GENTLY dont overtighten only to when you feel slight resistance on the screw. then back out 1 1/2 turns. This is the base setting. Turn at 1/8th turn either way until good high speed rev is obtained, but no further in than 1 1/4 turns out, or you will run the saw lean and cause damage. Check and replace your plug if fouled at all.
Feb 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Jan 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 136 chain saw
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Jan 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Dec 14, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
540 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
