Question about IBM 6400 Matrix Printer
Ibm 6400 imperfections in the impression of the right side, leave two columns blank, as if the hammers were not activated
    Problem Solver:
  • 8 Answers
You most likey have a bad fret or a dirty hammer bank cover
Jack
Posted on Oct 01, 2010
    Scholar:
  • 34 Answers
This is a easy problem... Have any question call 972-907-9771 x311
ibm 6400 - 51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Posted on Sep 10, 2009
    Master:
    Sergeant:
  • 460 Answers
It is a printer head problem. pls checked it.
Ryobi problems
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Jul 29, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
What does hb control mode on a IBM 6400 printer mean?
usually u get those on mod 14's and up and it could be a few things (i would try in this order from lowest to highest priced) coil temp needs to be set, hammer bank cables, shuttle and or cmx bd need to be replaced. Rory 708-597-4222
Jun 24, 2011 | IBM 6400 Matrix Printer
I have an IBM 6400 printer that flashes no hammer bank installed, and then gives me a type mismatch error try download again. I have the hammerbank installed, so I'm a bit confused as to why it would...
it seems your controller bd lost its config somehow. They do that if the NVRAM has gone bad. You might need to replace the Controller bd (CMX BD) Rory 708-597-4222
Jun 15, 2011 | IBM 6400 Matrix Printer
My IBM 6400 comes up with the error 086 Controller 15V fault on power up and therefore fails to get to the 'ready' state. Please advise on diagnosis of fault
The manual recommends replacing the hammer bank logic cable even if there is no damage to cable seen. You might do the cable shorts test recommended on page 263 of service manual
Oct 13, 2009 | IBM 6400 Matrix Printer
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Ibm ww1000 hammer solenoid is not working .lack of impression
The plastic cap on the silenoid plunger is probably broken, thet are availabe but a little rticky to install. We sell them for 15.00 including shipping.
Cleveland Business Machines
216-241-0027
Dec 10, 2008 | Office Equipment & Supplies
IBM 6400 missing decimal...
is there print missing??? if so the hammer fret in that location probably (90%) needs cleaning as dirt can get between the fret, it only takes the smallest amount of debris to stop fret working, you need to remove hammer bank to do this, fairly simple to do just lots of screws. the only thing to check when reinstalling hammer bank is that you pull it towards you ( front of printer ) before tightening the 3 screws, this is to be sure the gap between hammer bank and platen is roughly correct. there are 2 small grub screws at each end of platen to adjust this gap if you need to.
Aug 06, 2008 | IBM 6400 Matrix Printer
101 UPPER DRIVE SHORT ERROR on IBM 6400
The cause of this error is the Hammer Driver circuits are shorted to ground. The possible cause are :-
a. Faulty Controller board
b. Faulty Hammer Bank Cable.
c. Corrupt Microcode
Aido
Jan 14, 2008 | IBM 6400 Matrix Printer
IBM 6400 model i10 print problem
It's likely a "hammer" is defective. This can be caused by
a build up of ink under the ribbon shield and/or around the hammer "fret" itself or the fret is physically broken. Remember
that this is a "shuttle" printer and each fret covers anywhere from
one to three characters depending on model. Some cover fractions of characters as well. The problem will appear as either
data missing on the left or right margin or a blank column of missing data going down the page.
A technician is required to solve all of these problems as the
shuttle assembly must be removed.
Jul 27, 2007 | IBM 6400 Model i10 Matrix Printer
IBM 6400 Matrix Printer Logo
733 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
