Question about Watches
My watch is running to fast and is 9 minutes fast.
  • 601 Answers
Running fast beyond the 20-30 seconds per day window means it's time for a cleaning, and possibly some replacement components. This is best left to a professional, and requires a few hours of highly skilled labor, at the very least. You can certainly learn to work on your own watch, but it will take a lot of practice, a lot of mistakes made, a lot of patience, and some specialized and expensive tools to be learn to clean and rebuild a watch correctly..
Thanks
Smith.
Posted on Sep 10, 2009
Am....guys i want to know if my watch going 2 minutes back it will be forward after 28 minutes???and how can i fix it?? **its 2 minutes back 4 hours now.my watch is a jaga wr100m orange
You aren't making a lot of sense with this post either. This is a normal quartz watch. It isn't connected to a time server, so you need to correct it.
In the image, the watch says it is 9:41. If the correct time is actually 9:43, you advance it 2 minutes. You say 'back', but the better terms for a watch or clock are 'slow', or 'fast'. Your watch is 2 minutes slow, or two minutes fast? If the correct time is back, (the watch is fast) you need to advance 28 minutes.
Post here as a COMMENT, DON'T start a new post!
Feb 08, 2017 | Watches
My Rolex watch is 15 minutes fast
is it manual or battery if batter replace it if manual windit up more
Dec 17, 2013 | Rolex Watches
Having been unworn for about 6 weeks, due to the strap having a pin come out, it was repaired at an omega outlet and now the watch is running 4 seconds fast every minute. any ideas why??!!
Let you watch run down compleatly than rest the time and put it in a watch winder or activate it the same way you have been the problem is the watch has not been used for a time
Jan 29, 2011 | Omega Seamaster 2561.80 Wrist Watch
My watch is running about 15 minutes fast. And I have been unable to correct the time
Go to the website:
http://mygshock.com/casio-manual/3310/
this is an excellent website for all Casio Watches.
Jan 08, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Watch running fast about 5 seconds per minute. it had stopped because didn't wear it for a few days. didn't wind it at all. just set time and it started but now running way too fast. any...
mcdevito75 here, Depending on how new your IWC watch is, without running at all can be bad in the way that the oil in the movement can settle and more or less drain off the moveing parts, and without the oil distributed thru out the movement, your watch could run a bit fast. Re--starting your watch as you"ve done will help, re-distribute the oil, in the mean time switch your watches position on your wrist every couple of hours, crystal on top of wrist, then 2--3 hours later crystal turnned under the wrist, it may take a day or two for the condition to correct itself, if I'm right. Hopefully you have a warrantee with IWC on your watch. Hope this helps.
Aug 03, 2010 | IWC Spitfire Pilot Mark XVI Steel IW325505...
Tissot prs516 & it runs fast 1 minute every day
There is a solution, but you have to wait a bit. I'll contact Tissot tmrw and then will give you advise. It's 3.15 in the morning over here, so, need a little rest.
Aug 14, 2009 | Tissot Prs516 T91141731 Watch
MY Omega Speedmaster watch runs fast. How do I
Hi dgcgo. My advice, unless you're a watchmaker, is to take it to an authorised dealer or trusted watch repair shop, and get it done properly. The speed on automatic watches is adjusted by means of a tiny regulator, but the adjustments are minute and the watch is then usually bench-tested to make sure it is running ok. It's an expensive watch, so worth the effort, although if it's new, you can probably get it done under guarantee. Cheers; Eagle58
Jul 04, 2009 | Watches
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
Jan 26, 2009 | Geneve Watches
15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
Jan 21, 2009 | Seiko SKX173 Wrist Watch
Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
Oct 04, 2008 | Breitling Aerospace 455 Wrist Watch
Watches Logo
24 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
