Question about Matrix 226R (VPR226R) PC Desktop
Black sreen i have xp after io connnect to info hardware profile from microsoft the sreeen turn black. screen works at other computer. i have a matrix fgt 4100 model 210
    Scholar:
  • 150 Answers
I would suggest to check the video card. A faulty video may make such things happen.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Posted on Sep 10, 2009
Downloaded windows xp and screen when black
Turn the computer on, and leave it for 10 minutes.Once the 10 minutes goes by, press the caps lock key several times and see if the caps lock light goes off and on. If the light goes off and on, the computer is likely working, just no display is making it to the monitor.If this is the case, the problem could be your monitor, your cable, or your video card. Try another monitor. Try another cable. If none of that works, it has to be the video card or the motherboard.
If the caps lock key does NOT go one and off, then your computer is not booting at all, and it could be the motherboard, the power supply, memory gone bad, or some other hardware failure.
Jan 27, 2012 | Computers & Internet
My asus pc 1000he turns on but i get a black sreen with a blinking couser. i do not have a disk for it any ideas how to get it working again
Its a very Huge procedure,This happens when some of the main Files in your computer gets corrupted. This happens due to any hardware or software changes done on your computer.
So please Click the link below and follow the steps:
http://support.microsoft.com/kb/155053
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 11, 2011 | ASUS Eee PC 1000HE Netbook
I'm seeing pitch black screen with movable cursor
It's a black screen error.
Which is the operting system in your computer?
Did you make any hardware or sofware changes in your computer?
Follow this link if you are using XP:
http://support.microsoft.com/kb/314503
Follow this link if you are using Vista or 7:
http://support.microsoft.com/kb/2431700
Post back if it not working.
Hope this helps.
Cheers!!!
Jan 09, 2011 | Acer Computers & Internet
My xp laptop work fine but the only problem i have is the sreen is black and hard for me to see i cant see anything.. what should i do to turn my xp into windows 7
This is hardware problem. The LCD too dim. You may change it if you want to solve to problem. But it might costly. Other solution is you may use LCD monitor.
Nov 02, 2010 | Computers & Internet
Monitor sometimes does not work unless I press the on/off button and hold it down
fs31, Hi, I'm 12fixlouie. Will need more info about your Lucky Goldstar unit before I can give you advice on your "sometimes" black or blank n black screen monitor. What is model nuumber and when was it made? Is pc fully functional with spare monitor connnected? Did this problem just happen? Is unit covered by LG warranty? Did LG display work perfectly the day before? Do you know how to do the flashlight test when screen goes to black? Read my fixya profile for a little bit to understand the top two causes of ccfl backlit lcd monitor failure modes. Then do additional post on fixya and let us know what you are willing to do about your display. Your monitor's smps/ccfl inverter supply may need refurbishment (rebuild) because of common known problem affecting ALL brands of lcd monitors!!! Do your research first!!! Reading is free. Then come back here and rate this response if you learned something and feel this was helpful. 12fixlouie
Mar 22, 2010 | LG Computers & Internet
My laptop suddenly went bonkers. it was ok then when i turned it on it took ages for the screen to change from saying"microsoft windows xp" like 5 or ten mins...then screen looked black for a while after...
Sounds like your best bet is a fresh install of the operating system. Since it is an Inspiron, you may have the option of using PC Restore to re-image the system (Provided previous owner didn't hose the restore)
Info is here
http://www.fixya.com/support/r3705089-restore_dell_system_original
other things you can do are run diagnostics (Hold Fn Key and Press Power Button) and make sure you don't get a hardware failure in the diags (Passing diags is no guarantee of no faults, just none found)
If all else fails, boot to XP CD and do a clean install of Windows, then load the drivers.
Link to drivers:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
Driver install order:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/driver_install_order?c=us&cs=04&l=en&s=bsd&~lt=print
The I6400 is a good system, (I'm writing this on on) but the description you give tells me the OS is hosed and likely a reinstall is your best and fastest resolution.
Mar 15, 2010 | Dell Inspiron 6400 Notebook
Iam using windows xp sp-2 ,
Faster way: Re install your Microsoft Windows.
Slower way: Try to work around by pressing F8 during booting process and choose "Boot in Safe Mode". Locate the problem that could be caused by hardware driver such as VGA etc.
Another possibilities:
It might be not your windows, but your hardware. Could be the hard Disk or the computer it self.
To define it you should provide us some more information, such as:
  1. Did the power supply turn up?
  2. Did the PRE BOOT (BIOS initialization) appeared in the first place before "the blank screen" appeared
  3. etc
Looking forward to hearing again from you...
wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Mar 13, 2009 | Microsoft Computers & Internet
Computer problem
may be u have problem with the display driver or u have a corrupted windows xp try to run the windows in "ENABLE VGA MODE" if it works fine then just reset the display settings else u have to try to repair / reinstall winxp
mai me ur response @ vishwas_4u@rediffmail.com
May 01, 2008 | Compaq Evo N610C Notebook
Black XP Screen with active mouse cursor
boot in safe mode and log on to ur system with administrator account. Might be ur user profile is corrupted. Locate and delete the profile after taking backup of your Documents and Desktop. Restart the sytem and logon with the same user name and password and it will create a new profile again.
Mar 07, 2008 | Microsoft Windows XP Home Edition
Matrix 226R (VPR226R) PC Desktop Logo
80 people viewed this question
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
