Question about Whirlpool Duet GHW9150P Front Load Washer
Washing Machine Machine lights come on when I select a cycle but when I push the start button it will not start.
  • 53 Answers
Check the door lock. Whirlpool has had some problems with those in the past. If it is not locking the door lock assy may be bad
Posted on Sep 11, 2009
Whats wrong i push the power everything good, light on.when i push the start the light , is off
Depending on the washing machine there is a time delay between when the "Start button" is depressed and the actual start of the cycle, also the lid, on a lot of newer washers, must be closed to start the cycle. Give it 30 seconds to start, if it does not start, post again.
Dec 17, 2014 | Washing Machines
How do I reset the washing program ? I tried to change the washing cycle and it would not run. Now I cannot return to the original washing cycle.
Unplug the power then plug it in again. Now select the program you wish to run and start it. Make sure the door is well shut.
Dec 03, 2014 | Washing Machines
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I had the main water shut off and forgot to turn it on before starting my machine. Now it is stuck. I unplugged it for a couple hours, then plugged it back in and the lights just blink and the cancel...
try this:
Press "Stop" two times.
Push "Power."
Select the button for the desired wash cycle.
Press the appropriate "Modifiers" and "Options" buttons to adjust the settings.
Push "Start."
thanks to here
Mar 06, 2011 | Kenmore Elite 45986 Front Load Washer
Only Power Button lights up and beeps won't go off or power up
Try to reset the machine..Holding in reset button, also try drain cycle
Apr 13, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal De
