Older model kitchen aid 2 speed quitet scrub just wont turn on. but will work in the rince mode however no water either. Perhaps its the timer but I don' know how to check that or replace it either.
  • 25 Answers
Timers are not that hard to replace. Disconnect the power to the washer. There are two screws that hold the panel that contains the timing unit and other controls at the base of the unit, they go in about a 45 degree angle. Take those out and the panel will flip backwards and is hinged. Pry off the timer control knob. Separate the harness that is going into the timing unit. There will be screws on the back that hold down the timing unit or a nut in the front behind the control knob. Check to see if the knob has a set screw or allen type fastener. Replace the unit, reassemble and replug into the wall. Good Luck, Jim
Posted on Sep 10, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
Dishwasher beeping when you put it on rince or wash. checked water is on rince aid is full & salt is full
check to see if there is any sign of water leakage from the machine {usually from the rear} if the base is sealed it could be that the machine has gone into safe mode due to the machine thinking its got a water leak{some make and model dish washers ahve anti flood switches fitted to the base of the machine.
Jul 23, 2009 | Dishwashers
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Dec 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
