Question about HP Photosmart 2710 All-In-One InkJet Printer
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
I put the 4GB SDHC card in the SD memory card slot of the printer and I get memory card error.If I put the regular 1GB SD card it can read it.
I guess this means the printer can not read the new format high capacity SD cards.I wish that this could be fixed by some sort of driver update for the printer as it is very inconvenient,especially now that all cards are nearly SDHC.
    Sergeant:
  • 161 Answers
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Posted on Sep 10, 2009
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
I am using a stand alone photosmart 8450 ( with out computer ) it will print every memory card except SDHC the cards are fine as I use them in my Pentax camera
The 8450 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. SD cards will work in SD and SDHC devices, but SDHC cards will not work in SD devices.
Feb 27, 2011 | HP Photosmart 8450 InkJet Printer
4gb card is not recognized
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. A 4GB SD card is actually SDHC.
Nov 27, 2010 | HP Photosmart 812 Digital Camera
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp 8250 will nt recognize a promaster 4 gb sd hc card...i tied two
The 8250 works with SD cards. Your 4GB cards are actually SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work (SD cards will work in SDHC devices but not the other way around). You need to use SD cards 2GB and smaller.
Sep 13, 2010 | HP Photosmart 8250 InkJet Printer
I am trying to put a Lexar 4GB card into my HP Photosmart M517 but get "Unsupported Card" each time. What can I do?
The M517 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they will not work. You need to use SD cards 2GB and smaller.
Aug 04, 2010 | HP Photosmart M415 Digital Camera
Would not format memory csrd gigaware 4gb
The M425 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 15, 2010 | HP Photosmart M425 Digital Camera
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
980 people viewed this question
Ben Johnson
