Question about GE Spacemaker JVM1640SJ Microwave Oven
Burned out oven and house full of smoke
I put in a frozen dinner & timed for one minute and went out to finish yard work. I kept smelling smoke from outside and knew it could not be from the house so I kept working and when I came inside the smell was overwhelming. The pannini, along with the box it was on was charred and the oven was entirely black, the house filled with smoke and the oven is dead. Is there any hope for it?
    Problem Solver:
  • 3 Answers
The cavity is mostly metal. It will be hard to clean and never fresh again, but the oven function may be fixable. The oven has several temperture sensors. If one or more sensors have tripped they may have to be replaced. Check the sensors with an ohmmeter, make sure the door closes securely and go from there.
Posted on Dec 12, 2007
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
My KitchenAid microwave oven's model number is KCMS185JSS-4. Manufacture date is July 2005. It's been working fine until today, with an occasional glitch in the digital readout... sometimes the letters...
Either your high voltage rectifier or magnetron (or both) has failed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Sep 30, 2010 | KitchenAid Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
We brought a Tesco microwave at CULLOMPTON Tesco, Devon last week. It cost £29.00 on its first major use - cooking potatoes for ten minutes - smoke seems to be coming from beneath the machine - it has...
This is almost certainly some of the protective oils and varnishes which were applied during manufacture flashing off.
All new products of this type do this to some degree but your description seems to indicate that it's much worse than normal with your machine.
Ordinarily, you can expect this to cease after a few uses and if the level of smoke and odour you've described is to be expected then the instruction booklet should say so. But as yours has visible smoke and a burning plastic smell I'd recommend that you exercise your rights under the Sale of Goods Act and return it to Tesco for a full refund or replacement. The smell of burnt lubricant is one thing, but a burning plastic smell means you can never trust the oven to be safe: none of the many microwave ovens which I've dealt with have ever smelled of burning plastic unless there was a fault.
You won't find any objection from Tesco as they do have good customer service; and when I lived in Cullompton briefly earlier this year the local branch was even better than usual at keeping customers happy.
I hope that you have found my reply to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 05, 2009 | Microwave Ovens
Oven operating while empty
Yes, as long as you don't smell any burning, but as always, no microwave should ever run unattended.
Jun 03, 2009 | Microwave Ovens
Re: Overheat Microwave or...?
Magnetron (supplies microwave radiation [energy]) or any of the high voltage components internally. More than likely, the HV (high voltage) diode has burned out and is probably cheaper to purchase a new one than have someone repair it unless they can do it for free or you simply pay for the part.
Sep 29, 2008 | Panasonic NN-S540 Microwave Oven
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
207 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
