My computer not responding and totally black on my screen,what should i do.
  • 497 Answers
Option 1:
1. Try booting the Computer to Safe Mode by pressing the F8 key at Start up.
2. In the Safe Mode perform the System Restore operation: Click on Start -> All Programs -> Accessories -> System Tool -> System Restore.
3. Restore the Computer when it was not working normally.
Option 2:
1. Reset the BIOS to default and then try performing System Restore in the Safe Mode.
Option 3:
Reinstall the Operating System in the Computer.
Note: applicable for Windows Operating System only.
Check the link given below for more information also:
http://support.microsoft.com/kb/314503
Good Luck!!!!!!!!!!!!!!!!!!
Posted on Sep 10, 2009
    Master:
    Sergeant:
  • 460 Answers
It is a hardware problem. so pls checked it by hardware engg.
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
My screen has gone totally black. rebooting
The most likely problem in this situation is that the inverter is burned out. Do you hear sound? If your computer boots and there is sound, it is definitely the inverter board. You might want to try to replace the inverter board. I think it's about $15 on ebay. If you are tech-savvy you can take the computer apart. The inverter is usually located below the LCD screen. for more info on replacing the inverter click here http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
Sep 28, 2010 | HP Pavilion dv9000z Notebook
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Acer 5315 laptop black screen computer doesn't respond but there are lights on
perhaps hook up an external monitor. does that display information ?
Robert
Aug 28, 2008 | Acer Aspire 5315 Notebook
My creative zen v has totally blacked out
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Dec 17, 2007 | Creative Labs ZEN Vision:M Digital Media...
My V3 keypad is not responding
probably your flex connector get loose or defective... if you can open your fone try to check it... if not, just visit your service center..
Oct 31, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
