Question about Refrigerators
I have a Kenmore elite "stainless steel." It is not actually stainless steel; it is that newer finish they created that is supposed to be less trouble than stainless steel. However,I can't clean it properly. Water drips won't come off.
  • 867 Answers
Try liquid metal polish, make sure you only wipe in direction of grain, never across
Posted on Sep 10, 2009
How do I turn off the sound on my new Kenmore Elite microwave?
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
Dec 11, 2014 | Kenmore EM262A5E Elite Stainless Steel...
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore side by side ice maker sprays water into freezer
Is it actually spraying out of the icemaker or is it running down the back of the freezer?
Jan 31, 2013 | Kenmore Elite Sears & Other Brands...
What's a stainless steel?
Stainless steel does not stain, corrode, or rust as easily as ordinary steel (it stains less), but it is not stain-proof. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Stainless steel is 100% recyclable and is available in different forms, a stainless steel often used in knives pots and kitchen accessories.
Jul 25, 2012 | Camping, Backpacking & Hiking
I want to paint epoxy primer on stainless steel plate, what is the preparation required on the substrate? Or I can directly paint the primer to the steel plate and expect no problem on adhesion
I would sand the entire surface before painting anything. Be sure to clean surface after sanding so not to get debris in paint (bumps). Stainless is hard so you may have to start with heavy grit sandpaper and work you way to a fine grit. Personally, I prefer sandblasting on metal surfaces, but I tend to like a flawless finish when I paint. Never the less, paint needs something to adhere to. Stainless is polished most usually so nothing will stick to it (hence the name stainless) by sanding it you create grooves in the surface for the paint to hold on to.
May 27, 2011 | Cycling
Does not drain completely. Dishwasher less than 90 days old
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 20, 2010 | Kenmore Elite Stainless Steel 24" BuiltIn...
Is the film on a stainless steel refrig supposed to be removed
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 09, 2010 | GE Profile PSW26P Stainless Steel Side by...
Scratched stainless steel
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Mar 29, 2009 | Kenmore 99123 Electric Kitchen Range
Stainless dis-colored where the oven vent is, wont come clean.
Mar 29, 2009 | Kenmore 46123 Stainless Steel Electric...
Zap damage to stainless steel
You should try a citrus based stainless steel cleaning agent, this should take off the stain. Otherwise you can do a test on a concealed spot, stain it with Zap and then lightly brush over in straight lines with medium sandpaper in same direction as original. But try it on a concealed area first.
Mar 23, 2009 | Refrigerators
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
