Question about Canon SmartBase MP390 All-In-One InkJet Printer
Alaways telling black ink low - Canon SmartBase MP390 All-In-One InkJet Printer
    Master:
    Sergeant:
  • 460 Answers
May be your printer catridge is faulty. so you can checked it with new catridge.
Posted on Sep 10, 2009
How do I tell when ink is low in printer/scanner?
Use the desk top software that comes with the printer.
Feb 13, 2016 | HP Office Equipment & Supplies
Says i need to order more ink
Hello. Unfortunately, there is no way to bypass that notification when your ink cartridge is low on ink except to replace it with a new one. Hope I can assist you more with that.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Ink
clean the contact on the printer with a coffee filter, and clean the contact on the ink cartridge with the same.
install it and try again.
Oct 17, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge missing
you can tell me plz which printer use u .......i hope u use both color & black ink cartridge.....go to printer
setup .......???????if your black ink empty you change your near pc Or printer vender........
Oct 16, 2008 | Lexmark X2500 All-In-One Printer
MFC-240c ink erros. says i'm low/out after replacing
Your printer detects ink levels with an optical sensor that shines at the clear plastic in the center of the bottom of the cartridge. Once this area is no longer dark it will tell you to replace the ink. Since you installed full cartridges it could be that the sensor is cracking up. Another possibility is that you could have air in the ink lines that run between your cartridges and the print head. When this happens the printer cannot print the color that has air in the lines. You should be able to look in your printer to see the ink lines and see if there is air in the black one.
May 31, 2008 | Brother MFC 240C All-In-One InkJet Printer
Canon SmartBase MP390 All-In-One InkJet Printer Logo
old marine
old marine
