Question about Drills
CTH1202K2 Driller battery is not charging
Hi, I have a similar problem. Battery is not getting charged. The indicators shows it is charged but when used you find the battery is yet to be charged. Any solution !!!!!!!!!!
Shankar
  • 867 Answers
Either battery is shot or charger faulty. likely battery if older than 3 years
Posted on Sep 10, 2009
Testimonial: "Thanks"
Battery indicates being charged but is not being charged.Is this an indication that battery is in need of replacement
if the screen is showing that the battery condition is charging then power is getting to the battery
whether the battery is accepting charge or not would depend on the battery condition
if the charge light is on the charger ,it indicates that the charger is working but not necessarily supplying a charge to the battery
I suggest that you take the phone and the charger to a shop that specialises in batteries and have them both checked out
Jun 27, 2015 | Nokia E Cell Phones
Battery not charge
the battery may have developed a memory from continually recharging a partially used battery. The battery charges to this point and reads fully charged but when used it shows as flat because the charged portion is the bit that is used and not the whole battery. Replace the battery with a new one and only charge the battery when it shows as flat.
Sep 15, 2013 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a mini laptop which shutdown by itself a sudden. attempt to power iton both with battery alone and on charger plug-in proved abortive. it will only blink the power LED indicator when power button is...
Hi
Thanks for posting in Fixya
1st of all did you try on the other laptop with the same model and make? if yes then did you check in windows if the battery of that laptop is showing it is charging?
Try to remove the main battery keep pressing the power button for 15 - 20 secs. then release it. now connect the charger directly to the laptop and try to turn on.
If you want to install the battery back do not insert when the laptop is running. Turn it off and then install the battery back and load windows later check if the OS shows that battery is getting charged
Jul 15, 2011 | Computers & Internet
In lg rd 3000 voltage comes on battery tips but nighter charging shows nor store.
If there is voltage on the battery terminals then the battery must charge. Also if there is no indication of charge on the display then it can be relative problem of the board.
To confirm try to get hold of a similarr battery to swap and test so as to confirm if the battery is good and if the other battery shows a charging indication. If not the board can be faulty.
Jul 12, 2011 | Cell Phones
My Sony Ericsson K810i Mobile have a problem. It shows the charge indicator nearby 99 % and if i speak a cll it goes very low and says 'attention Battery Low' and if i leave the phone to standby it shows...
Hi, problem can be solved. When a phone battery indicates 99 % of battery life and runs down so quickly, it is caused by damaged battery.
When a battery cell is damaged, it will display charging full but itwill empty. You will need to replace the battery for a better battery performance.
When a new battery is been purchase, make sure it is charge it is charge up to 4 to 5 hours before use.
Oct 13, 2010 | Sony Ericsson Cell Phones
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Battery won't charge on printer dock any more?
I had a similar problem. If you look in the battery compatment you will see a small switch in the keyway that gets pressed down by the key (the plastic rectagualr bump out) on the side of the battery, if the battery is loose the switch does not get pushed down and the dock does not recognize the battery as a Kodak Batery that it should charge. I solved the prblem by taping a singe piece of paper on the opposite side of the battery so that when it slides into the slot it pushes the switch down, I've nver had a problem since.
May 13, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Drills Logo
57 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
