Question about Garden
What is the gap setting for the coil to flywheel on a mini mac 6? I have the engine out of the case and need to clean and readjust the carb. It is connected to the coil brace so if I take out the carb I will lose the gap. Using a set of feeler gauges one leg is set at .003 and the other about .005. I believe these should be the same and since it did not run as well as I thought it should I would like to set this correctly. My guess would be about .004. Can anybody verify this? Thanks
  • laserbeam Sep 10, 2009
    Thanks for the quick reply. I do appreciate the response but I think you left out a "0" or you put the decimal in the wrong place. I think you meant .010 which is what I will set it to.
    Thanks again.
  • 205 Answers
SOURCE: Gap setting between flywheel & ignition module
.010 of an inch
Posted on Mar 22, 2009
slohry
  • 87 Answers
SOURCE: I need a point gap setting for a skilsaw 1616 chainsaw
Plug gap is .027 to .030
You may be able to install a solid state ignition module. It's tricky but can be done.
Posted on May 06, 2009
nobby63
  • 10 Answers
SOURCE: chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Posted on Jul 09, 2009
  • 11 Answers
SOURCE: Engine running rich?
worn float needle or obstructed airflow (plugged foam filter)
Posted on Aug 07, 2009
  • 582 Answers
SOURCE: Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Posted on Sep 17, 2009
Testimonial: "I think you're right about the puller for the flywheel. Thanks for the input."
Air gap for coil
Assume you are asking for the air gap between the flywheel and the ignition coil?
Obtaining the correct gap from the manufacturer's specifications is best because although in theory a close gap is desirable for efficiency, flywheels grow as the engine heats up and a large flywheel can grow quite a lot.
Brass feeler gauges are best for setting air gaps as they are none-magnetic. A typical air gap would be in the region of 10 to 14 thou.
Mar 16, 2016 | Garden
John deere 110 engine cranks but no spark
Check that the ignition coil kill wire is not shorted to the frame.
Check coil to flywheel gap. A business card between coil and flywheel will set correct gap.
Coil could be bad or ignition switch is not releasing the kill wire in Run/Start positions.
Nov 03, 2013 | John Deere Garden
I have a mini mac six and need to know coil air gap
the easiest way to set that is to use a business card or book of matches
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 30, 2013 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Breaker points gap on kawasaki fa210d small engine
For the FA210D engine, points gap is 0.3mm to 0.5mm on max open. Coil to flywheel gap is 0.5mm. Timing has to be set when edge of left coil core lines up with flywheel trailing notch before the magnet.
Jun 16, 2012 | kawasaki W 2 (SS Motorcycles
My 5 hp briggs stopped running. No spark. took recoil off to reveal a rotten coil with wires rotted off. cleaned off the flywheel and replaced the coil with one from Napa. The engine does not have points...
Did you set the Air Gap correctly, it should be .020 inch. If the Air Gap is correct and you cleaned the pickup magnets, you should be getting spark. I have different color coded plastic sheets of the correct thickness to set the Air Gap on different engines. You could use a use a side panel from a plastic soda bottle (Mt Dew, Pepsi, ect) Place it between the Flywheel and the Armature/Ign Coil. Allow the magnets on the Flywheel to pull the Armature/Ign Coil together and then tighten the Armature/Ign Coil bolts. Carefully turn the Engine while pulling the plastic from between the Armature/Ign Coil Pickups. The Armature/Ign Coil is now properly set.
Generall speaking for a gasoline engine to run you need 3 things. (1) Spark, (2) Gas and (3) Air.
I hope this is helpful. UAW 974
Jun 25, 2011 | Sport & Outdoor - Others
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
Oh160170048F engine I removed the coil, now i don't know what the gap should be??
The air gap from the ignition module (coil) to the flywheel can be set with a clean and dry business card. Set the gap to maximum and snug down the bolts. Then rotate the flywheel around so that the magnet is positioned directly in front of the module. Place a business card in the gap, and loosen the bolts. The module will be drawn to the magnet. Tighten the bolts and rotate the flywheel to remove the card.
Dec 02, 2010 | Garden
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
