Question about IBM ThinkPad T30 2366 Notebook
When I insert a DIMM into my IBM T30 RAM slot, it is loose and is not recognized by SI. When I hold pressure on the DIMM, it is recognized. The RAM slot has apparently increased in size, possibly due to heat, and no longer provides a snug fit for a DIMM. Is there a fix? Thank you, Jon
  • jdcartr Sep 10, 2009
    Replacing the memory slot is not an option. A new mother board would be a better solution. I am wondering if there is a way to compress a memory slot. I have considered heating with a soldering iron and then compressing with pliers. My concern is that I will damage the slot or mother board. Is there a better idea?
    President:
  • 632 Answers
Try padding up the DIMM terminals with lead solder to make it tight and snug it fit into the RAM slots.
Posted on Sep 10, 2009
  • 601 Answers
The problem is with the motherboard slot for the memory.
You have to repalec it.
Thanks
Smith
Motherboard P5B-TMX-GB-SI diagram need to add addition RAM could do with contact numbers
DDR2 Upgrade for the ASUS P5B-TMX-GB-SI Motherboard 4GB kit (2GBx2), 240-pin DIMM, DDR2 PC2-8500 memory module
Part Number: CT2KIT25664AA1067
Guaranteed-compatible with the ASUS P5B-TMX-GB-SI
http://www.crucial.com/store/listparts.aspx?mfr=ASUS&model=P5B-TMX-GB-SI
you can see all of the crucial updates for this motherboard ram
hope this helps
2q==
Jun 16, 2011 | Computers & Internet
It looks like common problem: my OLD T30 can see only one 256mB memory slot. Does it make sense to install one 512 mB unit? Can T30 recognize 1gB memory? Thank you in advance
Hello
Yes, you system will support up to 1GB of ram, so, if i were you i would suggest that you buy a 1GB chip, this will give you the best performance upgrade. And, ram is so cheap at the moment, so, i think it will be the best option.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 09, 2010 | IBM ThinkPad T30 2366 Notebook
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Thinkpad T30 2367-23S will not use 2GB Ram Card
noway max is max. buy yourself a 1gb and don't try to beat the system or lose it.
Mar 03, 2009 | IBM ThinkPad T30 2366 Notebook
IBM THINKPAD T30 memory slot problem
This problem can be fixed very easily. Find some one who knows how to solder and have them reflow slot #2. My T30 has run great for along time then all of a sudden I only had 1/2 my memory. I did what everyone should do in that situation I Googled it and it brought me here. I happen to be Service Tech for a cell phone company. I took my Laptop to work with me and reflowed the side mounts and every pin around the slot. It has worked flawless ever since.
Jan 04, 2009 | IBM ThinkPad T30 2366 Notebook
Memoryt slots problem
This is a common problem, see this link for guidence. http://www.thinkwiki.org/wiki/Problem_with_failing_memory_slot
The only effective solutions are to replace the motherboard with one that has been modified by IBM to correct the issue or re-solder the cracked solder joints. If you choose to try the re-solder route yourself and have little or no experence with solders I recommend searching for additional links that explain more about the process. It does work if done right, but sometimes it takes more then one attempt when you're being careful not to get the motherboard too hot.
2nd slot issues
IBM's may need a bios update to read the 2nd slot do that first, and then check your setup for both slot availabilty. IBM always has, and always will make your life interesting.
got backup for your IBM Thinkpad?
Feb 16, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
136 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
