Ibimaster 400e is jammed
Our office has an Ibimaster 400e binding machine. It has jammed. We tried to pull a couple of pages plus a plastic cover out of it, but there are still pieces that are jammed. I found the manual online but it has no information on troubleshooting. I phoned the manufacturer (GBC) and their technical support person had no knowledge of this machine. I have turned the unit over and emptied the waste paper. What to do next? Thanks.
2 Suggested Answers
SOURCE: I need to downlaod ibimaster 400e user manuel
I have a Sharp 12 digital EL-1197 P II calculator, but I don't have a user manuel. How do I get one? thanks
Posted on Dec 13, 2008
Sircle Corp SircleBind CI-1500e Electric Spiral Binding Machine Jam
Hi Karen,
I would strongly suggest you find a local service technician to help you with this problem as the only way to release the pages is to wind over the electric motor by hand. To gain access to the motor the safety panels will have to be removed. The motor should be able to be wound backwards to release the punches from the pages, this will ensure the punches are not damaged.
If you attempt this repair yourself please make sure the machine's power cord is completely unpluged from the wall socket, not just turn off.
Dec 04, 2013 | Sircle Corp SircleBind CI-1500e Electric...
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have an Ibico ibimaster 400e Binder which is not punching out the holes correctly.
First, clear the waste tray of all hole punchings under the machine, and check the holes where the punchings feed from for any blockages. The worst thing is the clear plastic pages you use for covers, these can block up the holes. So you may need to pick them out of the holes using tweezers.
Then try again. If you have to punch clear covers, then try to do them with just a few pages on both sides so that the plastic sheet isn't the first thing the blades hit.
May 23, 2011 | Office Equipment & Supplies
search at this site for the manual:
http://www.acco.co.uk/literature_download/
Jan 21, 2008 | Office Equipment & Supplies
Ibico Binding Machine User Manual/Instructions
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
Kaye.Eldridge@acco.com
Jerry Quinn
Sep 28, 2007 | Office Equipment & Supplies
Printer won't eject paper correctly
I would try to clean the rollers with a damp rag. I would also recommend a good 'dusting' with some canned air. Pulling the paper out is never a good idea... you can always hit cancel to release the paper. If this printer is used in an office, I would put a little reminder on it for others. Hope this helps!
Sep 15, 2006 | HP OfficeJet G85 All-In-One InkJet Printer
197 people viewed this question
jasbo
jasbo
