Question about Garden
Engine ocsilates up and down and dose not reve up fast enough
    President:
  • 986 Answers
Mine did that and I cleaned my air filter and that fixed it I hope this helps you
Posted on Sep 10, 2009
My wife was mowing with our Husqvarna ride on CTH2038 and it started reving really fast so she disengaged the deck and ramp the throttle back to min but it kept reving so she shut it down with the key
Best thing I can recommend is to carry it to a trusted repair shop for them check it out for you.
Sound like governor control came loose or the governor self destructed. Without the age of the mower don't if the warranty will cover the repairs but the engine will need at least repaired if not replaced.
Oct 19, 2014 | Husqvarna Garden
Won't pick up gas
what kind of mower and size and model is it.
Sep 28, 2014 | Briggs & Stratton Garden
Generator trouble starting and running rough
ok simple things first, new spark plug, fresh gas, a decent dose of fuel cleaner a bottle doses 12 gallons so say if 3 gallons gas use 1/4 bottle (yes double dose wont hurt) , air filter, try running this first and see if it picks up over time, the methanol gas really crude's up small engines and the cleaner will hopefully clear it up, use fuel stabilizer with ethanol protection and dont let tank sit empty always full to keep moisture to lowest level. if this doesnt work then likely carb is fouled and needs rebuild
Jun 03, 2012 | Hammering
How fast can you ride the m50 w/o over reving the
Motorcycles and cars are designed so you can't over rev the engines in high gear. Air resistance will keep your speed low enough so the engine can't over rev. However, in a lower gear, you CAN over rev. If you don't have a tachometer on the bike, read your owners manual for suggested top speed in each gear. Or do a Google search for your bike and and "speed" and "gear".
Sep 07, 2009 | 2005 Suzuki Boulevard M50
Bmw 330d noise scremin and smokin when rev and loss of power
Sound like you have no boost. Turbo or actuator faulty
Mar 26, 2017 | 2001 BMW 330
CAR WONT PULL PROPLY AND SMOKES SINCE AND MAKES A SCREAMIN NOISE
you should not run the car any more and have the oil pressure checked to be sure the oil pump is pumping hell check the oil first you may have already done the damage i don't know how hard you were driving it when this happened .good luck
Jul 15, 2009 | 2003 BMW 330
Hi all,
So the only thing now is the light staying on ??
Disconect the possative cable on th battery..
That should re-set everything..
Jul 08, 2009 | 2003 BMW 330
Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
Jun 18, 2009 | Husqvarna 28cc Gas Line Trimmer
Engine running to fast 97 chev pickup 5.7 vortec
1997 K1500 Chevrolet
You can scan for error codes. Many auto parts stores have loaner meter for free. Call around Advanced Auto, AutoZone, VIP, NAPA, CarQuest, etc.
You can check for leaks in the intake vacuum hoses and other connections. With the engine running use a can of carburator starter sprayed on suspected places and see if engine speeds up. If so you found the leak!
NOTE: Do not spray starter fluid near or on hot engine parts or electrical elements, it will ignite very easily!
Have you check the fuel pump pressure ?
Jun 01, 2009 | 1997 Chevrolet K1500
Idles fast
Check for a intake manifold leak, we had some problems with seals used on the upper section of the intake on your engine, get a can of carb spray and spray it around the intake, see if the engine reacts, if it does you have a leak.
Sep 26, 2008 | 1993 Lincoln Mark VIII
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
