Question about Brother MFC 240C All-In-One InkJet Printer
Same problem - printer will not recognize new ink cartridge...
Help...i have same problem. Printer says no cartridge although I have just installed a new ink cartridge...
  • Project NOMAD
    Project NOMAD May 11, 2010
    Was it a proper Borither cartridge or a cheaper version ?
    President:
  • 2,306 Answers
Take out all the inks and power up, re install one at a time slowly and should be OK, if not, one of the sensors is bad and will need a shop repair. Make sure you can see ink in each of the clear plastic windows when held level.
Posted on Sep 10, 2009
I installed new printer cartridges - computer doesn't respond why?
Three possible causes -
- Your ink cartridge is fake or
- your computer set up requires you log on as administrator to install peripherals if it is a shared PC.
- You did not switch on your printer while your PC was booting to allow it recognize the printer set up.
Solutions:
If you can afford it, get another new ink cartridge from an authorised dealer and try again. Secondly, check whether there are administrator priviledges attached to installing new ink cartridges. You can view your profile setup from the Control Panel to confirm this
Finally, switch on your printer immediately you power on your PC so that the booting process can recognize your printer setting. Do check that the ink cartridge you are using is approved for your printer.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 21, 2012 | HP Office Equipment & Supplies
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
I replaced the ink cartridge with a new one, and the printer does not recognize it. Will not print. I opened a second new ink and installed it, but still no recognition. Help!
Sometimes ink will get on the contacts in the ink cartridge cradle causing the cartridge to not be recognized. Use a cotton swab with a little bit of alcohol to clean the excess ink from the contacts where the ink cartridge plugs in.
If this doesn't fix your problem, it's time for a new printer.
Jan 13, 2010 | HP DeskJet 6122 InkJet Printer
Printer says it's out of ink, but it's not!
if you refill the same cartridge that was in the printer
the printer would recognized the cartridge as being out off ink
you need to install another different black cartridge
the printer will identify this as a new cartridge
you then reinstall the previous cartridge back in
the printer will now recognized it as a new cartridge
Jun 12, 2009 | HP Deskjet D4260 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
429 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
