Question about Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
No channel programming scan, have antenna, no cable
Cannot get any channels and there seems to be no scan feature on olevia syntax 242 without cable,have antenna
    President:
  • 1,284 Answers
There is, it's just burried in the setup menu.
Posted on Sep 10, 2009
How do I scan for channels using an antenna?
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Syntax Olevia 532H 32 in. LCD HDTV
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
Jan 05, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I have a Syntax Olevia LT20HVK hooked up to a radio shack indoor antennae. I'm not getting any channels. The screen is just blue. How do I fix this?
Have you programmed your tv for your area and allowed it to scan for available signals?
Make sure your antena is properly mounted and pointing in the right direction for the stations you want to receive.
Hope this helps
Randy
Oct 10, 2012 | Syntax OLEVIA LT20HV 20 in. LCD Television
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
No channels found
you could try ant. on the tuner of the television and try to see if it grabs any channels on AIR ..if the scan goes all the way without finding any channels then the tuner of the television is not working. This means the mainboard will have to be exchange or repair..
This company called Amergence Technology is a 3rd party repair center and is able to offer repair services.. they could give you an idea on the repair cost and the process they have in place..
there number is 866-965-3842
Jul 27, 2009 | Syntax Olevia 226T 26 in. LCD Television
Olevia is not picking up my cable channels. Anyone know how to do a channel search or scan on this TV
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
Jun 20, 2009 | Syntax Olevia 537H Television
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
632 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
