My HP 1400PSC will only print on Vista
The scanner doesnt work, and the print head and other maintenance actions on HP arent present. The CD That came with it is XP compliant.
Doesn't power up
There is a possible short circuit over the printer head system due to moisture content caused by the previous action. Remove the printer head, power the printer, check the what happen.
Apr 05, 2015 | Epson PRINTER,ARTISAN 730
My printer has black ink but it will not print anything black. what should i do? i did take it out and replace it and it still doesnt work.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
HP 1210 printer won't align. Pages come out misaligned at end of page.
You need to re-align your printer, please follow these steps:
XP/2000: Go to start > control panel > printers > right click your printer and choose properties, go to maintenance and choose "Print head alignment" follow the steps on the printed page and you will be fine.
Vista/7: Got to start > Devices and printers > right click your printer and choose properties, go to maintenance and choose "Print head alignment" follow the steps on the printed page and you will be fine.
In case the steps are unclear, you will have to put your printed page under the scanner and press the scan button.
Good luck.
May 30, 2010 | HP PSC 1210 All-In-One InkJet Printer
My printer is hp officejet 5610 , printing of it work , but scan doesnt work ,help me
scanner drivers are separate from printer drivers. make sure to load the scanner drivers either from the installation CD or from www.hp.com directly
Jun 04, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photsmart 4180 will print but not scan.
Your CD's drivers probably aren't approved for Vista. Below is a link to the HP support site's Vista driver download page for your all in one.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1141647
Feb 12, 2009 | HP Photosmart 4180 All-in-One Printer
Loading HP scanjet 4800 onto vista
Hi there from Germany - English isn't the best but got the same problem solved so give it a try:
- first connect scanner to computer without having the drivers already installed
- next computer claims driver cd put in yours from XP or select downloaded XP-driver
- reboot
- try if scanner works - sometimes they do already
- if not head over to System management or system control what it's called in english
- choose add device and choose scanner
- now Windows tries to install a xerox-driver - allow this
- reboot
- and now it should work - if not sue hp! (But buttons for direct printing etc. might not be working anymore - except via the software itself - no more via the buttons
Hope I could help
Dec 20, 2008 | HP Scanjet 4400c Flatbed Scanner
Win vista doesn't accept hp scanjet 4400c downloaded driver
- reboot
- reboot
Hope I could help
Oct 21, 2008 | HP Scanjet 4400c Flatbed Scanner
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
22 people viewed this question
jasbo
jasbo
