Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The main belt keeps shredding. I need to know where the tention screw or bolt is. The model # is 1405 38'' cutting deck. It will work good for about 3 or 4 yards. Better yet is there a sight I can go to for a visual on schematics? what is the lenghth of the main belt? 56'' 57'' 58'' ???????
  • 389 Answers
Go to www3.sears.com, type in your 917.xxxxxx model number and you will get all the information you need
Posted on Sep 14, 2009
I need to replace a cracked deck and worn belt. I need the instructions on how to do these things.
1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
Feb 28, 2011 | Cardiozone Supersport Hr Club Commercial...
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
Instructions for changing the walking belt on my Cadence DX15 treadmill
1. Unplug the treadmill and remove the motor hood.
2. Use a permanent marker like a Sharpie and mark the roller positions on the bolt on the front roller and bolts on the rear roller- not all front rollers have this adjustment bolt.
3. Loosen the walking belt at the rear of the treadmill.
4. Remove the front roller adjustment bolt.
5. Some higher end treadmills use straddle covers that have an undermount or slide mount. If you don't see staples or bolts on the top of the cover, do not pry them up. If you do have one stapled or screwed down, use a flat head screwdriver or similar instrument, pop the plastic deck cover on the right hand side up (if you are standing on the treadmill like you are using it, the deck cover on the right side). If you see screws, simply unscrew and remove the screws. Screws are included to reattach the cover near the end of installation.
6. Remove the deck boltsmost have 3 or 4 bolts.
7. Once the deck is loose on the right side, completely remove the screws from the rear roller. Be careful with the plastic endcaps. The endcaps and the roller need to be removed in this step.
8. One person should hold the deck up and hold the front roller in position near the pulley while a second person removes the old walking belt (some models that do not fold and a very few number that do have a side handrail on the right side that attaches at the base of the treadmill…if yours does, remove this handrail before removing the belt). If you are talented, you can do this with a single person.
9. With one person holding the deck up and holding the front roller in position near the pulley, the second person should reinstall the new walking belt. Once the belt is in place, raise the deck up again and look underneath to make sure the belt is in the center of the belt guides that stick down from the deck underside. When tensioned, the belt guides should make the outside edges of the walking belt turn toward the center of the belt.
10. Replace the rear endcaps and rear roller and start the rear roller bolts. DO NOT TIGHTEN THE REAR ROLLER BOLTS IN THIS STEP.
11. Refasten the deck bolts. Go ahead and tighten the deck bolts fully in this step.
12. Refasten the front roller bolt and return it to the marked position (it was marked in step 2).
13. Replace if you have undermount straddle covers or fasten the plastic side deck cover with the enclosed screws if yours were screwed or stapled down. Removing the staples in the deck with a pair of pliers before reattaching the deck cover is not required but will make it easier to reattach.
14. Retighten the walking belt to the marked positions on the rear roller bolts.
15. Check the walking belt for proper tension by lifting it 2” to 3” in the center of the belt.
16. Test the treadmill for slippage and make adjustments (if needed) for lateral centering or tracking.
17. Once the belt tests good, replace the motor hood.
Feb 17, 2010 | Exercise & Fitness
Belt keeps falling ff
Check the routing of your belt you might be missing the tentioner pulley or you could even have the wrong size belt check your model number and reference it to the belt size.Good luck
Jan 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Belt keep coming off cub cadet 1042, all parts on deck have been replaced with new parts & still the belt comes off every time
my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
Oct 22, 2009 | Garden
Looking for a belt for G.E tumble dryer, model no: TL22PG. cant see code on belt as it is shredded.
take you model number to repair shop they will know
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Dryers
MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Jun 05, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
128 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
