Television makes a cracking sound and the picture is blank. power light is on and tv can not be turned off. I must unplug and start over to get power. Hooked up to direct tv box.
  • 601 Answers
The problem seems to be with the power supply. There might be bad components such ICs and rectifiers. I doubt the capacitors or fuses or the absence of high voltage because you did hear click.
The bad components are a result of heat or cold solders etc. If you want to repair it yourself then you should be having proper knowledge about the internal circuitry of the TV.
You should also require a multimeter and soldering equipments and schematics.So better you should contact a technician..
Thanks
Smoth
Posted on Sep 10, 2009
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
