Question about Yard Machines Garden
Burning to rich - Yard Machines Garden
  • 636 Answers
Mix your gas leaner between 40:1 and 50:1 is ideal, also some oils are a lot to do with smoking issues, you can try a better quality oil.
Posted on Sep 10, 2009
2000 Cadillac DeVille running rich city exhaust engine runs great uses boil it but doesn't burn have a blue oil leaves white smoke what could be the problem with it?
Running rich burns black smoke.
Burning oil, burns blue smoke.
Burning white smoke is steam and can be indicative of a damaged head gasket, or just weather conditions. Fuel contains water at molecular level.
Feb 03, 2017 | Cadillac Cars & Trucks
My seadoo900 has one carb and one plug is ok it has a brown burn the other is sooty black
sooth black indicates rich fuel burn-- air / fuel mixture is too rich . Check for blockage (air filter)
Mar 11, 2014 | Cars & Trucks
Burning rich
I suggest you take the carbs apart clean the float bowl blow out the jets.
Apr 29, 2013 | 2006 Harley Davidson FLSTNI Softail Deluxe
Vermont casting propane stove rich condition
First clean burner and injector and see how it burns , if still rich you can adjust the air on the burner by the injector a small sleve with a screw in it
Feb 22, 2013 | Grilling
What causes a 93 bronco to burn rich?
Have you checked the rings around the cylinders? That might be it.
Feb 08, 2013 | 1993 Ford Bronco
Blowing blue smoke on light quick acceleration on a toyota corolla 1990 after oil change oil level is normal
It sounds like your engine is burning engine oil. Depending how severe this problem may be , keep checking your oil level often. You may want to try an additive called ``NO SMOKE`` by Bardhall. It`s the only additive that actually works and the only additive I would suggest to buy. I don`t have confidence on many additives sold on shelves but I`ve used it and seen it work.
Feb 19, 2011 | 1988 Toyota MR2
1988 chevy camaro 2.8 liter multy port fuel injecton I recenly replaced the fuel pressure regulator, but the car is still running rich, idle surging, and misfire. I appriciate your help>
check you oxygen sensor. check the timing catilitic converters could be pluged now too. running rich can be a cause from that also an efect of running rich if theres another problem. check everything else before replacing the cats becausethey arnt cheap and if ist still running rich it will burn them out. also check the firing order if its real bad u may have one switched. that will cause the cats to glow and burn out.
Nov 18, 2010 | 1988 Chevrolet Camaro
Hi I traded a 92 Dodge Dakota with trans. problems for a 99 Ford Ranger that throws alot of smoke. Do you think it is the motor or cens. in the cat.
Your cat won't cause your vehicle to smoke, unless there is oil on it, then as the exhaust warms up, the cat will burn off the oil. Chances are, there is something wrong with your engine.
There are a few diagnostic steps you can make to see if you're burning oil, running rich, or have a leaking head gasket:
Check your plugs. If they've got oil or a filmy, soot-like deposit, you've got worn valve guide seals or worn rings, and you're burning oil, or you're running rich, indicative of other problems.
The exhaust "smoke" that you see, if it's like a white/gray cloud, could be steam from a leaking head gasket or water in the intake. If it's blue-ish, that's normally running rich. If it's black, you're probably burning oil.
Jun 27, 2010 | 1999 Ford Ranger SuperCab
BURNING TOO RICH
Check for vacuum leak in vacuum hoses (usually caused by heat where connected to inlet manifold).
Mar 23, 2009 | 1997 Jeep Cherokee Country
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
