Scans with bands across - Office Equipment & Supplies
    Scholar:
  • 52 Answers
Scanner part of the hardware has gone defective kindly replace the scanner.
Posted on Sep 23, 2009
Trying to run auto scan, But I have no air or cable option?
It should automatically pick up across the bands it can receive if hooked up to the correct source cable or air.
Does it give you an option in the installation menu to have it scan on both?
Oct 14, 2014 | Televison & Video
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
The scanner light on my epson 1670 fluctuates in intensity during scans which produce darker bands across printouts
check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Oct 06, 2010 | Epson Perfection 1670 Flatbed Scanner
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
When scanning or copying on the 7310 on my Mac osX 4.11 the scans and copies have large black horizontal bands across the page. The band is randomly places and. If the scan image is good, the saved PDF...
sounds as if your scanner bulb is fualty I would suggest doing a power cycle - by removing the power cord while on wait ten seconds and plug cord back in or try a different power socket (preferbly a direct socket without any adapters connected to it)
Jan 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
BC72XLT
You can't add to the preprogrammed search functions, but you can program frequencies from these bands into any locations you wish within the 100 programmable channels, where it will jump bands while scanning.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
29 people viewed this question
k24674
