Xerox error code 016-387 - Office Equipment & Supplies
  • info26144 Sep 11, 2009
    I have a xerox docucolor 3535 with build in fiery. while i was printing the printer displays me the error code 016-387. usually the error that begin with 016 are connection errors or software errors (as i know). i controlled the cables but everything seemed ok.
    can you halp me....
    can you halp me....
  • 3,741 Answers
The 016-387 error message indicates that:
  • Cause - The entered password is wrong.
  • Remedy - Enter the correct password.
computer has picked up the Auto printer driver and trying to use that, instead of local printer driver. Because of that it is using the default user password, instead of custom password.
If you need to change your password for the printer driver you can access it through the printer properties.
  1. Click on the “Configuration” tab
  2. Choose the account mode to “User”
  3. Click on “Detailed User Settings”
  4. Change the password details as per instructions from your printer administrator
thanks.
Posted on Sep 11, 2009
  • 854 Answers
Setting up a scanning template using CentreWare Internet Services(CWIS) will fail if the user login name is a domain user, for example,ADSdomain estadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Manual HERE
  • 555 Answers
Not sure exactly what Xerox printer model number you have, but I have seen this error on DocuColor 3535. According to Xerox technical info, the error code 016-387 means "Archived file crashes server, causes IOT fault" - It may be caused also by a 2003 power point file.
That means the printer is not able to process a file. The easier solution for that (but not may work) is to reset the printer.
I highly recommend you to visit the XEROX support site ( http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR ) and download the latest drivers and patches for your specific model number.
Posted on Sep 10, 2009
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Error code 010-319 on xerox DP 700 ?
error code 010-319 replaced fuser still the same
Jan 01, 2012 | Xerox DocuColor 12 Color Copier
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
690 people viewed this question
jasbo
jasbo
