Question about HP Photosmart C5280 Printer
I want to send a scan over my wireless network to my laptop. I have a HP Photosmart C4580 i press 'scan to PC' but i get a message 'Scan error, try scanning from computer'. How do i tell my scanner which of my laptops to scan to?
When I try to scan from the two pc's that use the same HP 4500 photosmart on a wireless network I get an error mesage. Yet when I connect a laptop with the usb cable into the printer HP 4500 it scans...
Base from the description of your problem this is some kind of issue with the software , and according to you already tried uninstalling and reinstalling.
So if you have not done reinstalling using the software from HP site better reinstall the softwrae using that and check if that corrects the issue.
Oct 18, 2010 | HP Photosmart C4580 All-in-One InkJet...
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
Hp 4580 won't scan. prints & copies ok
1. did you install the software to the computer?
2. what is the OS of the computer?
3. how is the printer connected to the computer?
4. are you trying to scan from the printer or from the computer?
5. are you getting an error messages when you tried to scan?
Aug 22, 2010 | HP Photosmart C4580 All-in-One InkJet...
How to get the laptop to connect to the HP Photosmart C7200 All-in-one series for scanning. Printing works from the laptop but I can't get it to scan into the laptop.
Can connect through USB or Wireless
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open
UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION
L3 file;
If you don't have the Cd Uninstall the software from Add and remove
programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=320478
5&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
On the printer :-
Press the setup Button (button with the monkey range)
Goto Network Press Ok
Goto Run Wireless Setup Wizard
Run it (make sure you should have the WPA/WEP key ) ready with you
Select the Network and get it connected to the network
On the computer:
Run the application that you have downloaded and install the software
Try to scan from "Hp Solution Center"
it should work
Oct 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP Photosmart C5280 Printer Logo
232 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
