Question about HP OfficeJet K80 All-In-One InkJet Printer
No power on unit
Unit working fine one minute then 'froze'; unplugged and when i re-started, no power at all. is there a reset or reboot button on the k80?
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony Televison & Video
My Vizio t.v. is froze in a photo screen. Hoq do I reboot my t.v.?
Hi Heather,
You may want to try to press the power button using your tv remote. If did not work unplug and re-plug the power cable then after 2 to 5 minutes open it again. Hope it helps.
Apr 30, 2014 | Televison & Video
Was in the middle of a game. Loud buzzing sound came on, game froze up, power button and reset button will not work, bu disc will eject. Screen shows frozen game and still buzzing with no disc in, cannot...
Disconect all the wires from the unit and leave for atleast five minutes. You need to even unplug the power cord from the recepticle in the wall or power bar. The unit should reset itself and hopefully turn back on clear of what was locked on.
Dec 10, 2010 | Nintendo Wii Console
My modem sbg900 keeps rebooting every 3 minutes or so if i turn off the wireless part it is fine
try to use the reset button
unplug it
remove from power ac source
then power on the modem and press the reset button together.
Nov 12, 2009 | Arris SURFboard SBG900 Wireless Router...
My c530 won't turn off and the sreen is froze
Unplug the GPS for a couple of minutes and turn it back on. It sounds like it just froze up and needs a good power cycle. Let me know if this helped! Good luck.
Aug 02, 2009 | Garmin Streetpilot C530 Car GPS Receiver
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Screen locked on "Checking media"
When the radio locks up on the Checking Media page you hold the + button to the volume and the MODE button wait for 3 seconds and it will turn off...  Thanks to Delphi for this assistance!!  Chris K.
Jun 02, 2008 | Delphi SKYFi3 XM Radio Receiver
HP OfficeJet K80 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
