Question about Lexmark X5150 All-In-One InkJet Printer
Cover open I wanted to check to see what print cartridge I needed so I opened the cover. Closed the cover and now it keeps saying cover open. It wont even shut off
  • kaineedwards Sep 10, 2009
    I moved the cartridge holder a little. Would that be the reason. Maybe it has to be reset?
  • mich cruz
    mich cruz May 11, 2010
    did you remove the cartridges? or move it just a little?
SOURCE: "printer cover open"
the microswitch is either stuch or broken and needs to be replaced.
omnipresent
Posted on Nov 04, 2007
SOURCE: cover open
Try this it worked
Remove the philips srewews onthe front of the cover when it is open. Once removed At the back of the unit 2/3 rd from the left there is a small switch if this is pushed in ( and held by whatever means sellotape etc it will opperate normally (to change cartridge you may have to re do)
Posted on Nov 29, 2007
SOURCE: COVER OPEN
Thanks for the posts and pic that helped me solve this problem :)
Posted on Dec 04, 2007
SOURCE: printer cover open error message
Thanks but this suggestion didn't work.
Posted on Jan 04, 2008
SOURCE: The cover open will not clear from screen
I had same prob this week after I changed the cartridge. At the back of the lid when open you'll see a plastic curved piece like an upturned sharks fin near the right side lid hinge. When the lid is closed this presses on a white plastic piece which in turn closes a very small black switch. The white plastic piece usually falls off and the isolating switch remains on so causing the prob. I turned the printer upside down and the loose white piece fell out. I couldn't refit it even after removing the paper guide tray so I jammed a piece of my son's pencil rubber into the gap instead so it keeps the switch pressed down and this fixed it.
Posted on May 23, 2008
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
A message keeps saying print cartridge access door
check that sensor function while open / close upper cover, some time hook type sensor connector broken and need replacement. check also roller for possible stock paper.
Apr 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Screen says open door clear cartridge jam, press enter. nothing is jamming it.
Open the printer and remove the cartridges and reinsert one at a time carefully. That should take care of it.
This can also happen if any of the covers are not perfectly in place or if there is a small sliver of paper or even dust being sensed by the printer. Open the covers and look for paper parts, slivers or dust and clean out if you find it. Then carefully make sure each cover is closed. Sometimes if you slam them shut the cover can distort enough to not close properly and is being detected as open. You also want to remove the paper trays and check there for jams and make sure the paper feeds correctly.
Oct 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
Printer cover open....error...
find the cover switch, must be lever is broken or switch gone bad.
Oct 31, 2008 | Lexmark Office Equipment & Supplies
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
MP600 - Says inside cover is open - but it's not!
This is a hardware problem nothing to do with software; somewhere inside the printer a cover is not closed correctly.
Jan 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP1060 won't print
Have you looked at the front cover to see if the tab there is broken? (this will tell the PC that the front cover is still open) So you'll want to go around the edges of the printer cover to see if there's anything broken and a small hole in which the tab would insert into. If it is the case, and you don't want to spend money on fixing it, then do what I do...Rig up a paper clip and electrical tape to work as the tab, making the printer think that the front cover is always closed.
Mar 26, 2007 | HP LaserJet 1020 Printer
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
