Question about RCA Televison & Video
I am trying to watch cable on my tv but it will not pick up a signal. All the cable wires are plugged in
    Problem Solver:
  • 5 Answers
1. pay your cable bill
2. make sure that your cables are hooked up right if cable has been paid
3. your cable provider should have a website for troubleshooting your own problems
Posted on Sep 10, 2009
I have sound but no picture. How do I fix/
Click on the input button on your remote to make sure you have selected the correct location of your incoming signal. If you are just watching TV and have a digital cable adapter, unplug the power to the adapter and plug it back in. If you have pinched a cable running into the TV and are using a DVD player or other device hooked to the TV you may need to try another cable. If you are using red white and yellow wires for connecting a device try removing the yellow wire from both the device and the TV and substituting with another yellow wire from another device. Also make sure you try additional channels if it's just the TV signal. If you have cable you can also unplug power to the cable box to cycle it off and plug it back in.
May 01, 2015 | Vizio VBR120 Blu-ray Player with Internet...
Screen goes blank while watching TV and playing DVDs
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Mar 19, 2017 | Marantz NR1602
Dvd connection
Check the connection wire for any internal conductor break. Check it with a multimeter.
Aug 13, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
I no loner have any cable, i want to just watch the regular free channels, how do i do this
U must have a antena hook hookup where ur previous pay cable tv wire plug into.Go into ur tv menu.Go to SETUP,Go down to CH. enter pick AIR not CABLE enter for scan for free air DTV broscasting.After finish scanning u will able to watch free air DTV.
Jun 18, 2010 | Sony BRAVIA KDL-46V3000 Television
It wont pick any channels while scanning
There's several possibilities here:
1. You could have the cable plugged into the wrong port.
2. How old is the TV? If it isn't brand new, It's probably analog, and won't work if you're trying to pick up an antenna signal. For that, you'd have to buy a digital converter.
3. Do you have a cable box? If so, your TV should be set to one of the "Video" channels, not the numbered ones. Try hitting "TV/Video" on your remote until you see a picture. Make sure your cable box is on.
4. Everything else would pretty much boil down to poor signal, or broken equipment. Call your cable company if you have cable to determine if it's a signal issue.
Oct 29, 2009 | Televison & Video
No signal
Try changing the order you turn on your TV and cable box, don't switch both together. The TV will likely skip the HDMI inputs if there is no signal there. Alternative you can change the TV's source after the cable box is on and that should allow it to not skip the HDMIs. You don't have HDMI to DVI adapter(s) in the line, do you? -Ken
Jul 30, 2009 | Televison & Video
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
Input Signal between TV and satellite dish lost
had that happen with my 42F430 and my PS3
every other input works except the HDMI
toke me the entire day to verify that its not my PS3 thats casuing the trouble
what i end up doing is "UNPLUG" the power cord of the TV and disconnect the HDMI cable from the PS3 then let the tv sit for 2 minute, then plug the power cord back in the TV then press and hold the power button for about 10 second.. to turn it on, after the TV boots up then i go to menu and do a factory reset
and after that it start picking up the signal from my PS3 again
Apr 09, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
