Question about Frigidaire Built-In Microwave
When I turn it on it makes a noise like it's sparking but it's not. There is a piece of cadboard on the inside right that is all burned what can I do.
  • 5,603 Answers
Any burned material must be removed as it is CONDUCTIVE and will absorb further energy from the microwave.
Never run the microwave without adequate food/water/etc as that can cause arcing.
Posted on Sep 10, 2009
Burnt cardboard piece inside oven
go to www. repairclinic.com and get it.
God bless you
Jul 08, 2013 | Microwave Ovens
Popping sound coming from my panasonic NNCD997S
The following works better if done in "low light".
Put a cup of water or small bowl in the unit, close the door and turn the microwave on.
If there is anything that you can see in the cooking area, there should be sparking and it is coming from something metal, even a small piece of aluminum foil that was left behind. The thing causing the sparking needs to be removed.
If you hear the noise and it is coming from inside the area of the microwave that you cannot see then you can:
1 - Take it to a repair shop.
2 - Depending upon the cost for repair, consider buying a replacement.
If the noise is inside the machine DO NOT CONTINUE TO USE IT. Get it FIXED OR REPLACED for your own safety.
Good Luck
Apr 06, 2013 | Panasonic NN-S969 Microwave Oven
Microwave sparks
Look in side and make sure there is no pieces of aluminum foil or metal hidden inside. If not I would not use until you have a appliance repair person look at it.
Apr 07, 2012 | Dacor DMT2420 1200 Watts Microwave Oven
Bulb flickers and makes an electrical spark noise but only for around 30 seconds on starting programme
Is it an electrical spark noise or is it actually sparking inside your microwave oven? Watch as you heat something. This also might appear to be the bulb flickering, when it's actually a sparking. I only know how to fix it if it's an actual spark, or what might be called "arcing." This is not supposed to happen.
Inside your microwave, there is a "cover" over the area where your bulb is. If this cover has a burned place in it, or an actual hole in it, then it's your "waveguide cover." And this is the easiest thing to repair. I myself will not attempt any electrical repair, but this waveguide cover was a breeze.
You have to purchase replacement material... Then, when the replacement material arrives, remove the wave guide cover from your microwave, trace it, cut it out and put the new one in. It is very easy to fix. Sort of like paper dolls....
Google "waveguide cover" and you're on your way! IF that's the problem....
Oct 09, 2010 | Microwave Ovens
Arcing inside microwave
unless you are familiar with these, leave it alone. Over time small particles of food become carbonized inside the oven, hence the electrical display. the solution is to clean it after every use.
Oct 02, 2009 | Magic Chef MCD1110ST Microwave Oven
Sparks pops odd burned smell
I would certainly take it to a repair shop if you want to try and salvage it. Until then keep it off and unplugged.
Feb 14, 2009 | Frigidaire PLMV168 Microwave Oven
FLASHES INSIDE OF MIRCOWARE AFTER IT IS STARTED AND MAKE NOISE
It could be a magnetron sparks to the open metal inside the m/w cavity or some broken wire on high voltage side. It is not HV transformer (when burn create a lot of smoke and bad smell). Magnetron needs to be replace.
Dec 03, 2008 | Whirlpool GT1195SH Microwave Oven
Frigidaire Built-In Microwave Logo
96 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
