Question about Lexmark X1150 All-In-One InkJet Printer
Printer not communicating with PC and I unplugged printer and my computer shut down, had to unplug computer from power source and replug to get it to come back on. What is the problem?
  • 27 Answers
SOURCE: computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Posted on Feb 05, 2009
rjwharris
  • 102 Answers
SOURCE: no communications computer to printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
  • 19 Answers
SOURCE: Computer cannot communicate with printer
either port or driver problem. you may have to make adjustments in BIOS under peripheral devices. default is auto, change to assign manually and assign a port for com 1, com 2, printer.
reboot
right click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MANAGER; scroll down to com 1 and com 2 ports (above printer port) make sure no yellow explanation marks which indicate a port conflict. NO PRINTER WILL PRINT.
go to mfr website and download driver for your printer
click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MGR;
scroll down to printer port; right click; PROPERTIES, click on change driver; browse over to where you download drivers; keep going down the tree until you get to DRIVERS (select the folder with your operating system) click on it to OPEN into dialogue box (in change driver wizard which is open) and hit enter; THE WIZARD WILL INSTALL THE CORRECT DRIVER FOR YOUR PRINTER.
HAPPY PRINTING.
Posted on Apr 26, 2009
tbock86
  • 68 Answers
SOURCE: computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
Posted on May 09, 2009
Grubhead
  • 5151 Answers
SOURCE: the computer does not communicate with the printer
If using Windows - Leaving the printer on and plugged in- go to the add Hardware and you can either do an auto search or a manual one for the printer.
Posted on Jun 26, 2009
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
I can not down load pages or pictures from my laptop to printed. It all locks up and does nothing.
What is the operating system running on your computer? How is the printer connected to your computer, wireless or hardwired with a usb cable? A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If you're connected wireless, simply unplug and replug your printer into the power source to reset it. Reboot your computer as well. If usb-connected, disconnect your printer from your computer first. Then, unplug/re-plug printer into the power source and reboot pc. Try to print again.
Jul 12, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
When I connect the printer to PC, and press the scan button, the display says that " downloading applicaitons"..No idea what the printer can download?.. When I try to scan from PC , it says...
Try to disconnect the printer from your computer. Restart your computer. Unplug and replug the printer into the power source to reset it. When the printer turns on, reconnect it your computer. Doing this usually fixes minor communication issues. Try to scan again. If problem continues, it could be a firewall issue. Make sure to allow full access to all Lexmark softwares and printer communication processes in the program rules/permissions for your firewall.
May 10, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x6150 printer stop printing,I have xp window
Try to unplug the printer from your computer. Then unplug and replug the printer into the power source to reset it. When your printer turns on, reconnect it to your computer. Doing this usually fixes minor communication issues. If this does not help, you could try uninstall and reinstall the software.
Mar 23, 2011 | Lexmark X6150 All-In-One InkJet Printer
Lexmark x4975 printer not communicating with computer
This article from the Lexmark website on No Communications Error When Trying to Print or Scan might help resolve the problem. Or simply unplugging and replugging your printer into your computer and into the power source can help fix minor communication issues.
Feb 21, 2011 | Lexmark X4975 Wireless Color Multifunction...
Problem communicating with printer message when printing. printer says offline
This could be just a slight communication issue. Try to unplug your printer from your computer. Unplug and replug the printer into your power outlet to reset itself. When the printer powers on, reconnect it into your computer. Doing this usually fixes minor communication issues. Thanks.
Feb 21, 2011 | Lexmark X73 All-In-One InkJet Printer
Is offline how can I bring it online
It could be just a minor communication issue. Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect it to your computer. If problem continues, you may refer to these articles for further troubleshooting:
- 'Communication Not Available' Error Message and Print Job Stalls in Print Queue - Error: "Problem communicating with the printer" or Bogus Error Messages
You may also contact Lexmark technical support for additional assistance. Thanks.
Feb 17, 2011 | Lexmark Color JetPrinter Z54se InkJet
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
My computer is'nt comunication with the printer
It could be just a slight communication issue. Try to unplug your printer from your computer. Then unplug the printer from the power source. Replug after 10 seconds. When the printer turns on, replug it into your computer. Doing this usually fixes minor communication issues. If error continues, you may refer to this article on 'Communication Not Available' Error Message and Print Job Stalls in Print Queue for troubleshooting steps. You can also contact Lexmark technical support for additional assistance. Thanks.
Jan 21, 2011 | Lexmark X2600 InkJet Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
